- First Name
- Eric
- Mar 21, 2025
- Hampton, VA
- 2024 Maverick
- Engine
- 2.5L Hybrid
I have a mystery that I am trying to figure out.
Owner's Manual describes and many post have shown that the Maverick has two variant instrument panel clusters, 4.2 and 6.5 inch. ForScan has nothing on the subject as best as I can tell within the IPC section. I did a full (all sheets) search on the Livnitup sheet and "6.5" only shows up once on the ACM module. I understand that the ACM module is associated with the Center Touch Screen Audio/Nav system, not the cluster. Very Odd.
It is not an idle mystery. Other users on here have described how they can configure how the 6.5 screens can manage if the Seatbelt minder might show up using just the basic menus for the cluster. It is also on page 117 on my 2024 Owner's manual that there is an option Select Screens that would enable or disable showing the Seatbelt as optional to display. But nothing in ForScan or Livnitup that would at least expose this difference to user configuration. 4.2 only shows up in two sheets, ACM with the "6.5" and again on the PCM module but in this case its really a find of RDRGS 361 mm (14.2").
