Hybrid Remote Start Stopped Working
Johnkn
MD
I’ve remote started my hybrid in the past, today though trying multiple times, it no longer works. I press “lock” on the fob 2x then start 2x and only get a red flash on the fob. I confirmed all doors were locked, battery voltage is good at 12.5V at the pins with the truck off. No “accessories disabled due to low voltage” errors on the Ford app..
jeffrol48197
2007 Explorer, 2009 Focus, 2019 Explorer
Check in your vehicle settings in the dash - you can enable and disable it there...If you find a box next to remote start, and it isn't checked, you accidentally shut it off...
Firedog
Ken
Pennsylvania
Nissan Versa
You only press lock once and then start twice on mine and it works every time. Maybe that is the difference?
Are the doors actually locking when you press the lock button, and you should be getting a horn honk double pressing (you only need to press lock once for remote start, BTW). Have you tried remote starting next to the vehicle or via the app?
jsus
2022 Ford Escape Hybrid AWD
Have you tried both factory keys while standing right next to the vehicle?
Johnkn
MD
See original post, yes doors are locked, double horn. Everything is as it should be except no remote start and red LED on fob.
.thanks
TedTX
Ted
San Antonio TX
In the past, remote start could only happen once. Its was reset by driving truck.
I think they emulated past systems where remote start was a separate device and limited.
Obviously not a single hardware device limit anymore. We can schedule starting once a day and it does day after day.
Just offered an opinion, may not be broken or wrong.
fossil
ernie
ohio
ok I'll ask. Does it remote start with your phone?
Johnkn
MD
Op here.
Remote start is still enabled on the center screen. The truck will remote start via the app, however I get the red light on the fob when trying to start with the fob although it have absolutely worked in the past. The Horn and door locks all work with the fob. I’ll try the other fob when I return...
Ford Motor Company
Official Ford Account
Dearborn, mi
Hi there. Can you send us a DM with your VIN and dealership info? I can look into this for you.
Brown0
Charlotte, NC
Lariat Lux
Op here.
Oddball suggestion here, but have you tried disabling the check box, completely shutting down and locking the truck, then going back in and enabling, shut down and lock, and then retry remote start? "Have you tried turning it off and on again", if you will.
FlyGuy09
2023 Mavrick
Any update to this, mine stopped working. 2023 Lariat Hybrid.
