Fix for radio glitches : SSM 50411 - updates ACM and radio firmware
Leand60
Clearwater FL
2023 Maverick XL Hybrid
I don't know if it's available, but I found a 7 year old update for my Maverick today was installed via USB . Is it downloadable/installable through the website?
Not that I'm aware of. The dealer did this under warranty. Personally, I would hate to brick the radio in a new vehicle.
Leand60
Clearwater FL
dgnx6
Louisiana
My old vehicle I just downloaded the update to a usb drive then update the info system. You could have one sent to you too with the file already on it. Wondering if that would be available in the future.
Dirt820
2022 Maverick XLT
Ford Maverick Fix for radio glitches : SSM 50411 - updates ACM and radio firmware 2A2D2AF2-5789-40E1-BB24-274297E79667
Downloading the update as we speak.
Edit: it worked! The fm channels can now be changed more than once per trip. Truck had to be connected to home Wi-Fi, took About 20 minutes to download (slow connection here) and updated in the background while I was driving around. I started the truck back up and as I was pulling out of a parking lot, I got a voice prompt that the software had been updated.
huunvubu
coppell tx
2023 Ford Maverick Hybrid
The glitchy radio can be fixed by your dealer with SSM 50411. This will update the ACM, updating the radio firmware.
My Maverick was built on 11/29 and shipped on 11/30 and has this exact same firmware version and revision.
This update is only for Mavericks produced on or before November 29th
Ford Maverick Fix for radio glitches : SSM 50411 - updates ACM and radio firmware 20220119_081522
huunvubu
coppell tx
Are you sure it is SSM 50411 and not SSM 50410?
Renho17
Ren
Hybrid Mav
I tried that and it would not update. I believe this is something that must be preformed by the dealer.
yes Mavs have updates you can do your self. You don’t need the dealers anymore. If it doesn’t find it you usually have to try searching 2-3 times.
phones hotspots usually don’t work for this type of stuff, You need a home connection. Public hotspots will usually block the connection too.
For people that live in tall buildings or apartments that can’t reach their wifi. Best bet is to go to a friends house that theirs reaches the driveway or sit in their garage.
pnorwood54
paul
ALTO BLUE XTL AWD-4K-FX4-360
worked for me
pnorwood54
paul
worked for me
duh, figured out 1/2 way thru that it works with engine off/ key in middle/on position.
( too long with push start)
Fx4hOok
Kevin
MA
Maverick 2.0 FX4
Did it at dealer, was not able at home for some reason
bbhaag
I just went out and checked and our radio is using the latest version. It was built over the last week in December. So depending on when your truck was built it might already be on the latest software version.
Zackmix2020
Zack
Los Angeles
2022 ford maverick 2.0
Recently came across an issue when I’m using apple car play. It would will just randomly press areas of the screen constantly and the only way to fix it is to close the maps and re open
Fx4hOok
Kevin
MA
Maverick 2.0 FX4
Its only for Nov 30th back builts
vegman
South Carolina
I had the same result, mine took a little longer than 20 minutes though. I can't comment on what was corrected yet, as I was bummed out over how long it took to upload and install this clunky software and walked away. I'm hoping it straightens out the radio freezing issues. Will update after I have a chance to deal with it when I'm not frustrated, but this update method was replicated.
