Hybrid died in stand still traffic
NeilsTruck
Neil
Albuquerque NM
2013 Fit, 2005 F-350, 2018 CR-V, 1965 F-100, 1957
My maverick died today in rush hour traffic! I was sitting still in along line of cars talking to my wife on the phone when my maverick just died. no power at all, no phone, would not restart initially. Without power I couldn't put it in neutral to push it out of the way! I jumped out to help three or four vehicles get around me. After about three minutes I tried again and thankfully it started and I was able to make it home without any other problems. Is this a one off flaky electrical problems I read about here on the forums? I received my maverick on 3/28/23 it had 6032 miles when it failed. I haven't had any of the recalls done yet, thinking if they come up with a fix for the fire recall would have them all done at the same time. The only consistent issue I have is most mornings there is no interior lighting and I chalk that up to the inadequate 12v battery that Ford has yet to address. Has anyone else had this particular problem and how do you move the maverick if you have no power to get the truck to neutral ?
Storm Ranger
Raleigh,NC
97 Explorer, 17 RAV 4, 22 Lariat Maverick Hybrid
Hate to here about your troubles with your hybrid. I have a hybrid also. Maybe check and clean your battery terminals.
Stock411
HI
2022 Ford Maverick XLT Hybrid
Maybe it’s the dreaded 12v battery cable. Get the dealer to test
I’ve had mines for almost 2years and 29k miles on it with nothing but oil changes and a window switch going bad. Sorry to hear your experience
Hkak45
K
Cody, WY
2022 Maverick Ecoboost
MavTime
23 Maverick Hybrid XLT
What is your drive like, how far and how often? Have you noticed any deep sleep low power mode signs like the interior lights not coming on when you open the door, or app notifications?
BlueSpec1
Gene
...how do you move the maverick if you have no power to get the truck to neutral ?
You'd need an external 12V jump pack if the truck's 12V battery is the problem.
You need most of the Maverick's electronics working to shift into Neutral.
Service Manual-
307-05A Automatic Transmission External Controls - Automatic Transmission – HF45
2023 - 2024 Maverick
Description and Operation Procedure revision date: 07/30/2021
External Controls - Overview
Overview
The shift by wire system uses a rotary dial GSM to interface with the PCM to select gear positions.
The shift by wire system needs a 12 volt power source to move the transmission out of park.
2023 Maverick Owner's Manual-
EMERGENCY TOWING - HYBRID ELECTRIC VEHICLE (HEV)
If your vehicle becomes inoperable without access to wheel dollies or a vehicle transport trailer, it can be flat-towed with all wheels on the ground, regardless of the powertrain and transmission configuration, under the following conditions:
• Your vehicle is facing forward for towing in a forward direction.
• You switch Neutral Tow on.
• You release the parking brake.
2023 - 2024 Maverick, Procedure revision date: 01/5/2024
Ford Maverick Hybrid died in stand still traffic Brake Shift Interlock Actuator Manual Override - 2023 Maverick Hybrid
NeilsTruck
NeilsTruck
Neil
Albuquerque NM
I regularly do not have interior lighting the first time I get in truck in the morning. I don’t use the app so no alerts. I lock the truck if I’m leaving town without it. I love this truck but the flaky electrical system needs a permanent solution as does the engine fire issue, Ford are you paying attention? I use the truck daily for mostly short trips and only have driven it 6k miles in eleven months. The only way I will take it to the dealer is if it happens again or I hear on this forum that Ford has a real fix for inadequate charging system!
Old Fart
Mid Florida
2022 Ford Maverick XLT; 2016 Prius ECO
Had mine 'towed' into the dealer yesterday, the drive screen was going crazy with a variety of things needing service hopefully the video loads, after 6 hours waiting for Turds emergency service to show up the truck was fine, three hours running at the dealer they couldn't replicate the problem, I'm wondering if the extended warranty is still available.
Ford Motor Company
Official Ford Account
Dearborn, mi
Hello! Could you please send us a PM with your VIN and the name and location of your Ford dealer? I'd be happy to see how I can assist you with your Maverick power concern!
Carjack
Belleville, IL
2014 Taurus
Have your battery tested at the dealer. Mine was bad and it was replaced with a higher capacity battery, no charge. I have not had any trouble since. 23 Hybrid
MAVRICK
Any
2024 XL
@Ford Motor Company
@fordvideoguy
Hey Ford, mentioned many times before ...
1) Add the ability to mechanically (i.e. without applying external power) move/roll out a dead HYBRID Maverick out of a compromised (dead) position. Currently, 99% of the time, when a Maverick is dead, it has no OEM onboard power ... the HYBRID must have an external power source (like a Jump Box) available to supply enough temporary power to allow the user to turn on the vehicle and move it out of a locked "P"-to-"N" so it can be rolled out ... IMHO, this is a serious safety issue.
Headbanger
Ron
Finleyville PA
2023 Maverick Hybrid Lariat
That’s would be a scary situation for sure. The fact that you haven’t had any recalls done yet is a red flag for me. I would take it in and have everything done so it’s up to date. I recently had some issues with the sync system. Found out that I was a version behind and used a USB to update it myself. That was the solution and it hasn’t acted up since. Good luck and don’t lose hope!
Deleted member 7089
Guest
I thought the fire recall only applied to MY22 with production dates up to mid 22.
NeilsTruck
NeilsTruck
Neil
Albuquerque NM
My hybrid was built in March of 2023 and delivered at the end of March. I received the fire recall notice.
