Hood struts problems
Halo9x
Hal
Abilene, TX
Maverick XLT 2023
I installed the hood struts this weekend. Hood lined up perfectly opens and closes fine. Woke up this morning its cold out today hood was giving me problems. The struts are cold and don't give that little bit when you pop the latch . It keeps the hood from releasing on the second pull. I have to press the hood down and release it multiple times. I will ne sending it back.
You need to get a spring that’ll help with your strut problem. It’s not expensive and easy to install.
Ford Maverick Hood struts problems IMG_0389
Ford Maverick Hood struts problems IMG_0388
For the 6 to 8 times I open my hood a year I think I'll stay with the prop rod.
Simple, easy, cheap and more than likely, I'll never have to replace it for the life of the vehicle.
Ford Maverick Hood struts problems IMG20241008130450
jbwilli
bennie
1997 FORD EXPLORER SPORT, 2009 FORD EXPLORER EDDIE BAUER
Check out these videos. The poster identified the problem as to why these add on strut kits have operational issues. He also came up with a fix that just might make it reliable! 1) the install. 2) his solution His fix combined with a pair of properly power matched struts for the hood weight just make it reliable!
MrJP
Chapel Hill, NC
2022 FORD Maverick XLT Hybrid with Co-pilot
That's one of those mods that sounds like more trouble than it's worth. The factory support strut works fine.
There are no factory support struts, which is why people are installing these
MrJP
Chapel Hill, NC
I am not sure he installed his correctly or if they were defective - I have failed to fin anyone else reporting this problem
ianjay
Ian
Toronto, Ontario, Canada
2024 Maverick Lariat Hybrid , 2008 Ford Ranger
Was there something wrong with the originals ?
The original struts? Mavericks don't come with hood struts, just hinges and the prop rod. It is a common thread that re-starts about every time someone buys and installs the aftermarket kits.
My hood won't open...have to take it to the dealer.
oysterville
Oregon
The hood isn't designed structurally for support struts, so naturally there will be issues.
jbwilli
bennie
Agreed! Not only does a hood with support struts require more hood strength where the struts attach, but it MUST have a spring assisted 'pop open' functionI to lift it slightly and allow the strut geometry alignment into the 'aligned to open vs aligned to close geometry!'
IMHO, Strut-less hoods are just one more example of how auto designers save $$$ in production cost (by eliminating expensive parts), while increasing the total cost for the vehicle! Give the buyer less and charge them more! What a concept (to which most buyers are blind to)!
