High voltage battery warning
jimbo722
Atlanta, GA
I was traveling on the interstate on the way back from Tennessee to Georgia and stepped on the accelerator (basically punched it) to get around a big rig, all of a sudden I get a "tow truck" icon on my dash and the accelerator is unresponsive, so I think I was in electric mode only if that. Fortunately, I was close to an exit and was able to coast to a stop in a parking lot. I put it in park, whereby the shifter dial then locked into park, could not change it. My wife read a blog on the internet (the owners manual is useless) to wait a few minutes and everything should work, that turned out to be true, so we were able to be on our way, but scary as hell to be on the highway and your vehicle suddenly shuts down. My Ford Pass app showed a Hight Voltage Battery warning.
Has anyone else had this happen?
Ford Maverick High voltage battery warning Screenshot_20220407-072403
Ford Maverick High voltage battery warning Screenshot_20220407-072331
Something definitely not right, take it to your dealer. Sounds like it went into limp mode or something
rlhdweman
Random Lake Wisconsin
Alternator problem?
Ford Motor Company
Official Ford Account
Dearborn, mi
Hi there! I can look into the concern you're experiencing with the battery on your Maverick. Will you send us a message with your VIN and the name and location of your local Ford dealer?
jimbo722
jimbo722
Atlanta, GA
VIN: 3FTTW8E36NRA32665
The dealer is Angela Krause Ford/Lincoln Mercury located in Alpharetta, GA.
jimbo722
jimbo722
Atlanta, GA
I have an update to the High Voltage Battery Warning that I and others on this site have reported. My dealer had my truck for 2 weeks and after discussions with Ford engineers, I was told that Ford advised my service dept.to return the truck to me, basically, they have done nothing aside from recognizing the codes they read and apparently "excessive clutch slippage", but from what I was told they have no idea how to fix it. I reminded my service rep that I felt that this is a very serious safety issue, with the truck suddenly shutting down while driving and telling the driver to pull over. To say I am frustrated that Ford does not take safety seriously is an understatement. I'm hoping that if enough people report this problem, then Ford will issue a TSB and maybe even a recall once they can pinpoint the exact issue.
If anyone else on this site has had this issue and has not reported it, do so now, please. The more of us report it, the more Ford may take this seriously.
Ford Maverick High voltage battery warning PXL_20220624_191955821
Scupking
2025 Ford Maverick XLT Hybrid
It is a safety issue...Keep pushing for a solution as it will happen again at some point...
Scupking
I should mention this has happened 3 separate times...not good!
Isn't that when the lemon lawn kicks in? Same issue 3 times and the dealer can't fix it.
RJC
RUSS
NL CANADA
2022 FORD MAVERICK CARBO GREY AWD XLT
Glad i have the eco, seems to have less issues.
