Help
Vomamansr
gary
Long island ny
Had a service done on my 24 Maverick included in that Service was an oil change. Well what happened? I just want to change my oil now and I noticed there’s two of the T 30 screws holding up the shield are missing. I know I’ve seen it on here before anybody know the part number for those screws. Thank you.
BK007
BK007
OH
This is what I did to my Tremor Skid plate hardware should be the same..
Hardware Specs: Ace Hardware
• Washers: M6-1.0 1 1/2" Stainless Steel Fender Washers (to prevent pull-through)
• Body Clips: M6-1.0 U-Nut/Body Clips
• Bolts: M6-1.0 (1.25" Length) Hex-head Body Bolts with attached washers
Nibyak
Virginia
2025 XLT
The only time I ever had missing bolts or stripped nuts on the splash shields on multiple ford’s, was when I had someone else do the work. It’s very easy to strip those tiny nuts if you use power tools and have a heavy trigger finger. I understand that there isn’t much profit in an oil change, but I think they should fix it. It’s probably easier and quicker to stock up on nuts and bols and check after every service.
Fcnrwy
Jerry
Wisconsin
Maverick XL Area 51
If YOU reinstall...
I only HAND TIGHTEN my bolts..
TOO easy to strip-out Nut with a power tool... :unsure:
Jerry
