Help with Ford Front Deflector
ryde4ever
Dennis
Indianapolis, IN
2024 Maverick XLT (Also, 2016 Civic)
I purchased the Ford front deflector online at Ford. I watched a video on how to install. It doesn't look too hard. The problem is that it is missing the alcohol pad (which is no problem), but it is also missing the surface prep pad. Is this a glue actvator? Or maybe just a stronger cleaner like mineral spirits? Will there be any issue with not using that prep pad?
Thanks!
BlueMav43
Roger
NE FLA
2023 Ridgeline RTLE, 2018 Tahoe LS
Thanks!
I just now finished installing an AVS Aeroskin. It came with both alcohol pads and a pad with “adhesion promoter”. After using the alcohol pads used adhesion promote. You could definitely see it. It is more than a stronger cleaner. Not sure but I’m guessing you could fine adhesion promoter at an auto parts store.
BlueRaven
Iowa
24 Mav, 01 CRV
didnt bother with the prep pads. just cleaned it really well with glass cleaner and a microfiber. then again with a lint free rag. been on for over 4000 miles.
Ford Maverick Help with Ford Front Deflector 437382058_8309240489093331_6753390177166131186_n
fossil
ernie
ohio
HoiToid
With this new"streamlined" design where it sticks right on front of hood, does it help to deflect bugs and debris from windshield or just protect the paint on the front edge of hood?
The "old style" ones usually stuck up about an inch from the hood which seemed to "deflect" quite well. Just curious because I haven't installed mine yet and looks like once it's on, it isn't going to be easy to remove if it's doesn't help protect the windshield ( have seen some threads on MTC about Ford using a "softer" glass on their windshields lately; don't know if that's true for Mavericks)
HoiToid
Appears, not soars. Spellchecker strikes again
