Hauling long pieces of lumber again
Phimosis
Larry
Santa Clarita, CA
If you rear ended someone and those projectiles impaled a person in the car in front of you, I’m pretty sure you’d be found guilty of negligence. Food for thought.
Timothyd
Tell me about the front support for your canoe. Mfr? How does it attach, and is this something that's sorta permanent or could it be removed when not needed?
It's a rooftop rack I got from Amazon. Comes off and installs in a minute. Works well. Attaches with a clamp.
MetalsGeek
Rough
Torrance, CA 90503
Down to just the Mav
Your photos indicate that rack attaches in the black rooftop strips, which I like a lot.
The only one I can find on Amazon is this one that has straps way down to the door jamb.
Ford Maverick Hauling long pieces of lumber again RackAck
Timothyd
That's the one. I started not using those clamping straps to save time. The rubber feet on the stand offs have a pretty good grip and it works well without them for the canoe.
White Thunder
Donald
Sapulpa, Oklahoma
2022 Maverick XL
Sure don’t want to run down road with 6 to 8 foot of lumber sticking out back of truck bed.
This is how I use to haul long lumber in my Prius. Odd that no one can design and market a utility vehicle that actually meets the largest mass residential market. Also odd if I hauled this in my Prius I could actually close the hatchback. Guess we will just continue to make do with whatever vehicle we have. 🤓
🤓 :oops: I guess you can say THANK GOD for the little window.
🤪:rolleyes:
jonshep
SW Oklahoma
My XLT had the light trailer hitch on it and I have a 10' utility trailer that I haul my mower with. I have never pulled the trailer with the Mav. I fabricated a light hitch to fit the receiver and moved my old horse drawn JD sickle mower (yard ornament). I normally use my F250 to haul stuff. I have a 23 foot goose that handles most everything I need to move. If it's bigger than that, I have the lumber yard deliver it. I don't own a flag.
tic105
CT
I routinely carry up to 12 foot boards in my Maverick. Even though the bed is about a foot shorter than my old Colorado, I find the tie down options in the Maverick make the job much easier. Here's my system - fast and very secure:
Ford Maverick Hauling long pieces of lumber again 1755278682781-78
Cancunbadlands
Cancun
Cancun
Wood in the cab that will shoot out the window under emergency braking or an accident! Asking for a rear window replacement
Jah.
Jah.
Central Florida
I have roof mounting rack ( Yakima)with clamps that I used on my F150 for hauling a 12 ft row boat (boat gone) and adjusted it to fit maverick if I need it for something . Never had a problem with it with over 10 years of use on F150 .
themartymac
Marty
Victoria - Canada
2026 Ford Maverick XLT
For temp jobs when you have some spare lumber - could be as effective with smaller/cheaper lumber, and made to hinge for storage between jobs...
