Gun rack / storage [*** Storage Talk Only *** No Glorification, States, Laws, Permits, Politics or Usage Discussions]
HarlzMav
Harley
Jacksonville, FL
Hyundai Genesis coupe
I see a large potential for 3d printing something to fit the slots that would allow you to at least lay a shotgun or long rifle across the back portion of the rear under storage (a u shape most likely) And probably a few other options such as 3d print mag holders. I'll see about working with my brother to design something.
Barracuda340
Abilene Tx
Curious about the center console vault for my carry pistol. I wonder if it's got enough room for easy secure storage for a Glock 23. I plan on a magnet mount under the dash as well. Ya gots ta have options.
73bluebronco
Jeremie
Tulsa, OKlahoma
2022 maverick, 1973 Bronco, 2017 Fiat
I just got my magnet in but am not sure about screwing in through the plastic to mount it. Doesn't feel real robust back there. Thoughts on a 2 part epoxy for mounting it?
Barracuda340
Abilene Tx
You drill through the plastic, and you run machine screws through the face side with nuts and large diameter small hole "body washers" to back it up behind. Works just fine.
BigT
South Dakota
You can get a MOLLE panel and attach it to the rear of the rear seat back and then mount your rifle/shotgun to that. Be aware of open/concealed carry laws in your state and how they may or may not apply to a long gun.
cannon
mark
oregon
2022 Maverick XL awd
Last night, I started to wonder where to store my shotgun when we go on vacation in a few weeks. I put mine in a guitar gig bag and fits nicely behind the rear seat with pockets full of extra shells.
SLINGSHOT
Charles
NE Iowa
2017 RAV4
NAA in my pocket. Something a little bigger in the door pocket. Works for my RAV.
ShadowBlack XL440
Robert
Northern Ohio
Quite simple, under the back seat, out of sight, quick and easy to get to, there's a lot of room there for long guns and other gear.
I have a magnet mounted up front too, had to build a spacer for it and mount it on its "side" for hang gun.
Stay loaded!
David, Can you private message me a picture of the magnetic mount that you are using and wher e you have it mounted?
Jwoadie
Jeremy
Cedar Falls
I'm going with grey man tactical. RMP
Clock Doc
Mass
Ford Maverick 2.0 ecoboost, Ford Crown Victoria
My pistols are always on my hip never stored away in my vehicle. Long guns I used to sling over the back of my seat in the standered cab if I needed to transport them. Maybe a bed box of some sort for the long guns.
dcs12345
TX
07 Chevy
How much room is there behind the rear seat against the back of the cab?
might be able put a rifle/shotgun back there….hard to tell
under the seat, it looks like if you had the two side compartments full, you could lay a gun case across the middle maybe? I don’t know how much space is between the middle divider and the bottom of the seat.
Ford Maverick Gun rack / storage  [*** Storage Talk Only *** No Glorification, States, Laws, Permits, Politics or Usage Discussions] 93F6A54D-0F4B-44E8-B4A3-72107001F5BC
AGW078
Andrew
Mississippi
23' Maverick Lariat Tremor
How about this for a long gun? Overhead and out of the way.
