Gas cap problems
Marty
2026 Ford Maverick Tremor
Over topping off the tank can let gas get into the blow off vent, that can collect dirt and clog over time. At worst your emission charcoal filter can get contaminated.
My second click is not needed but I’d never do a third or fourth click.
No and no
Okay.
Is it possible to take a picture of your current MPG screen?
This is a current picture of mine taken 5 minutes ago.
Ford Maverick Gas cap problems 20250330_090952
I know this back and forth gets frustrating but I'm just trying to troubleshoot what could possibly be the problem.
dhaskit
Dann
2024 Maverick FX4 Lariat
My humble opinion:
It sounds like a calibration error between the in-tank sending unit and the display gauge. As far as I know, the only thing to try would be to have the dealer's service department replace the sending unit under warranty, which may or may not resolve the issue. Sending units just send an electrical resistance value to the display, not an actual fuel level in the tank and they are not always right.
Noteworthy;
Everyone who flies a high wing Cessna aircraft knows there are only 2 times that the fuel gauge is right.
- When the tank is filled to the top and the gauge reads Full.
- When the engine stops running and the gauge reads Empty.
Everything in between is just an estimate.
Good luck, my friend.
Seabart
Seabart
chas
Pittsville MD
2025 ford maverick xl
My humble opinion:
Noteworthy;
Thank you
Seabart
Seabart
chas
Pittsville MD
Okay.
Thank you very much for the picture.
For an EcoBoost your mileage is very good. I'm stumped at this point.
It might be something that the dealer has to look into.
Thank you for indulging me with my questions. I'm sorry I couldn't be any more help.
Good Luck
GB
Seabart
Seabart
chas
Pittsville MD
Good Luck
GB
Thanks for your time
jorgy_bc
Glenn
Galiano Island, BC, Canada
Maverick Lariat
Couple of things I've noticed on my Lariat hybrid that may help.
The fuel gauge is a little more sensitive to downhill situations compared to other vehicles I've owned.
It doesn't take very much nose low to change the reading
and
it does react to changes a little slow.
Seabart
Seabart
chas
Pittsville MD
and
Thanks
and
thanks
sfurash
Stan
Maine
2024 Maverick Lariat Tremor
I fill to the first shut off click, then I slow fill til the second click then stop, that’s only about two tenths of a gallon btw.
No problems at all.
I had a problem similar with a jeep wrangler and it turned out to be a faulty fuel level sensor which meant at least in a Jeep replacing the fuel pump as it was unit.
Assuming you are still under warranty I would take it to the dealer
James K
NY
2022 Maverick,1960 Bugeye, 1973 GT6, 2016 R1200GS, 2024 KLX300
Does anyone see there gas gauge drop from full to three quarters after fill up I am thinking gas is running out of the filler neck when full, not over filling tank seems to drop pretty quick
I have to agree with Glen, if you lost that much, you'd see or at least smell it. Must be a gauge issue.
Seabart
Seabart
chas
Pittsville MD
Took it to dealer and they said the fuel pump assembly and sending unit needed to be replaced waiting on parts
