Front USB Ports (Types A and C) - Issues. Replacement.
litleboy
Esteban
Las Vegas
maverick 2023 XL, Maverick 2024 XLT
How do you remove that from the panel?
Do you have to drop the panel to depress the tabs, or can you just pull it out from the front?
Thanks
Push on both sides at the same time with flat trim removal tool, if you push one side it will pop back in most of the time when pushing the other side.
DeadWolves
None
My front USB ports recently stopped working, no charge or connection (accent lights around ports also not lighting up). Does anyone know the fuse location and # for the front USB ports? I am getting conflicting info elsewhere online and the user manual isn't helpful ether unfortunately. I want to check the fuse first before ordering a replacement port hub. Thanks!
BlueSpec1
Gene
Media Hub may be getting power from the ACM.
Ford Maverick Front USB Ports (Types A and C) - Issues.  Replacement. 1775761161667-bh
OK Spitty
Harvey
B.C.
Volt
I have the hub removed and one of the plug connectors. But I don't know how the free up (disconnect) the second plug. I've read to "squeeze" the sides of the plug. When I do that nothing happens. How did you remove the plug/connectors? BTW, I have a 2022 and experience the same issue with disconnecting when hitting some bumps. I've got my new one ready to install except for one connector.
YazYaz
Northeast
2019 Ford Escape
You need to squeeze and pull harder.
OK Spitty
Harvey
B.C.
Volt
Thank you. Problem solved
