StarBug
StarBug
2025 Hybrid Lariat
I have a couple of old Miltona MNCD60 dashcams. From what I see it creates .MOV files.
I tried to upload an example but, they are too large...
VLC plays the videos just fine but it would be great to see the map/gps data...
Thanks!
You will need to find some file service to host them at. You could put them on Google Drive and share them via a link or try something like Wormhole.
EffNo50
Central California
2024 Lariat Hybrid white on black
...So I guess the first ask would be to not require 3 channels and the second to have a plugin to allow my file name format for the Thinkware.
2nd this (2 channel option). Please add an option for the number of channels, since someone else also wanted 4 channels.
EffNo50
Central California
StarBug
StarBug
2025 Hybrid Lariat
I started putting my requests into Github.
Awesome, thanks! I was going to go through and compile a list from here of what people want added, but I haven't gotten to it yet. Feature requests as Issues in GitHub will be much easier for me to track.
Everything I've seen here so far seem like import and doable things, I just need to organize them and do them.
StarBug
StarBug
2025 Hybrid Lariat
My thinkware F200 Pro has different naming conventions so I was trying to change the names of some test files to get it to load them but having no luck when using the open folder button. I keep getting the "No trips found in this folder" error. From looking at the testvcode it looks like they need to be named like this:
fn triplet_shares_base_key() {
let f = parse("2026_03_15_173951_02_F.MP4").unwrap();
let i = parse("2026_03_15_173951_02_I.MP4").unwrap();
let r = parse("2026_03_15_173951_02_R.MP4").unwrap();
assert_eq!(f.base_key, i.base_key);
assert_eq!(i.base_key, r.base_key);
Where it would be YYYY_MM_DD_HHMMSS_XX_F.MP4 (and _R for reverse) but when I name two of my camera's MP4 files using those naming conventions and dropping them into an empty folder I get the error.
The naming convention for the regular recording files for my camera are: REC_2026_03_06_07_25_52_F.MP4
and if it matters my directory structure looks like this:
where cont_rec is the regular driving files, evt_rec is for "events" etc. But for my testing all I was doing creating a new folder and dropping in two files and naming them 2026_03_06_072552_01_F.MP4 and 2026_03_06_072552_01_R.MP4 and also tried dropping in an "I" file in case that was required by just duplicating one of the two and renaming. But keep getting the error.
Forgot to mention, this is on my Windows laptop.
I'm working on this now. It would be easier with example files, but I've managed to find some info on the internet about this camera so I'll post up my attempt when it is done and you can test it.
It won't require renaming files, it should just "detect" the file naming structure from the folder and "do the right thing."
StarBug
StarBug
2025 Hybrid Lariat
I'm working on a release that should work for 1, 2, 3 or 4 channels.
I'm also going to push an initial attempt at a Linux build.
nbmav
Kevin
North Bend, WA
2026 Lariat
I tried uploading a couple of the files for you here and it failed as they are too large. Also tried on the Github issue and that had the same problem. They are 84MB each. Do you have an FTP server or something where I could drop them?
b25crew
St. Louis MO
2024 Maverick, 1992 Mustang GT Convertible
Sent a DM with a link to my google drive which should be a raw video from the Miltona dashcam.(Yeah I'm an idiot for not thinking of this!)
StarBug
StarBug
2025 Hybrid Lariat
Can you put them on Google Drive? That has worked for others. If not I can try to set up some sort of server, I just don't have anything open to the net at the moment.
nbmav
Kevin
North Bend, WA
2026 Lariat
Just DM'd you a link to two of the files.
nbmav
Kevin
North Bend, WA
2026 Lariat
I think you forgot to put a link to the built windows installer for this release, all I see is 0.1.0.
StarBug
StarBug
2025 Hybrid Lariat
nbmav
Kevin
North Bend, WA
2026 Lariat
I see them now on Github, just about to run again.
