StarBug
StarBug
2025 Hybrid Lariat
Just DM'd you a link to two of the files.
Got them, thanks! This should provide the information I need to make GPS data work for you too and not just the camera playback.
StarBug
StarBug
2025 Hybrid Lariat
Sent a DM with a link to my google drive which should be a raw video from the Miltona dashcam.(Yeah I'm an idiot for not thinking of this!)
No worries! Got it! Thanks, this should allow me to make your video playback and hopefully include GPS data too.
nbmav
Kevin
North Bend, WA
2026 Lariat
The new version works great! I don't have the GPS module hooked up but maybe I will now. I'm in the process of getting the back camera in today, was thinking of trying to run it through the headliner (no sunroof of this replacement Mav) instead of along the edge of the headliner as I did in the '25 as the curtain airbag deploying destroyed the rear camera cable.
StarBug
StarBug
2025 Hybrid Lariat
Haha, yeah I was about to say, 'Oh, testing shows you don't have a GPS' 😅
I ran mine down the A pillar, across the bottom of the doors and back up, which turned out to be very easy and my Wolfbox provided plenty of cable to do that, so I didn't mess with the headliner. I found a post somewhere showing images of someone who dropped their headliner and it convinced me not to mess with that.
nbmav
Kevin
North Bend, WA
2026 Lariat
Yeah, I was looking at that headliner post to, maybe I'll take a crack at like you did it.
StarBug
StarBug
2025 Hybrid Lariat
This was the best video I found showing how some of the bits come apart:
He is going along the passenger side and I went on the driver's side as that is where I got my OBD2 port power from, but the panels are all the same.
The trim pieces at the bottom of the doors popped off easily and fishing it from "door to door" across the B pillar at the bottom was very easy.
nbmav
Kevin
North Bend, WA
2026 Lariat
Interesting, I hadn't come across that one when I did the install in the '25. I did just install the rear before seeing this post. Ran it along the bottom passenger side but managed to do so by just tucking it and and only lifting the end of one of the trim pieces. I then ran up the rear pillar and across tucking into the headliner as I needed to get past the sliding rear window. All working again.
StarBug
StarBug
2025 Hybrid Lariat
StarBug
StarBug
2025 Hybrid Lariat
Interested, mostly in a Linux (Debian / Ubuntu / Flat Pack) version
The latest release has an AppImage build that should work on Linux. Let me know if that doesn't work for you and I will keep pursuing the Flatpack route.
lewiskauffman
Lewis
Chambersburg PA
2022 Ford Maverick XL
Hey all,
I built a free dashcam viewer and wanted to share it in case anyone else here is frustrated with the software that comes with their dashcam.
I have a Wolf Box 3-channel setup (front/interior/rear) and the stock app is... not great. Buried speed controls, no real scrubbing, sluggish playback. The paid
third-party viewers are better but none of them handle three channels well. So I built my own.
Trip Viewer is a free, open-source Windows app that:
- Plays all 3 camera channels simultaneously, perfectly synced
- Shows your position on a live GPS map as the video plays
- Has a timeline with speed graph so you can jump to interesting moments
- Lets you click a side view to make it the main view, double-click for fullscreen
- Can import footage directly from your SD card with integrity verification
- Auto-detects and groups your files into trips — no manual organizing
- Is lightweight (~3 MB install) and uses hardware video decoding so it's actually smooth
You can download it here: https://github.com/chrisl8/trip-viewer
Click "Releases" on the right side, then download the _x64-setup.exe file. Just run the installer and you're good. Windows may pop up a SmartScreen warning since the
app is new — click "More info" then "Run anyway."
One thing to note: most dashcams record in HEVC format, and Windows needs a decoder for that. The app will check on startup and point you to the Microsoft Store if
you need it (it's a one-time install).
Right now it's built and tested with Wolf Box dashcams specifically, but the architecture is designed to support other brands. If you have a different dashcam (Viofo,
Thinkware, BlackVue, etc.) and want to try it, let me know what model you have and I'll see about adding support.
This is a personal project — I'm a software developer and built this with help from AI tooling (Claude Code). It's MIT licensed, totally free, no ads, no tracking. If
you run into bugs or have feature ideas, you can open an issue on GitHub or just reply here and I'll see it.
Windows only for now, but the tech supports Mac/Linux so I'm open to porting if there's interest.
Happy to answer any questions!
I have the Thinkware DC-M2-FG (VHL3Z-19G490-K). Would love to try the software!!
StarBug
StarBug
2025 Hybrid Lariat
If it doesn't work, put some example video files on a share drive somewhere like Google Drive or Dropbox and send me a share link and I'll use them to learn how the videos are encoded and add support for them to the application.
lewiskauffman
Lewis
Chambersburg PA
Thanks, I will do that!
lewiskauffman
Lewis
Chambersburg PA
Tried your software with my Thinkware DC-M2-FG(1). Downloaded video to iPhone 16 (iOS 26.4.2). Transferred video to PC Windows 11 ver. 25H2 OS Build 26200.8246. Worked great. I have to learn more about the camera and how to load the rear camera video but your software with the latest Ver 0.3.0 worked great!
I will try using the sim card directly on my PC next.
Thanks for the software
