FORScan tweaks for a US Maverick in the UK
RadioDoc
RadioDoc
Fairchild AFB, WA
2023 Maverick XLT Hybrid Lux
Made some updates to the list - changing the Country Code in the IPC module updated the TSR display to use the round UK/EU style speed limit signs (before it would read the signs no problem, but the display would show a US style sign), and went into the AS BUILT to do the seat belt display removal mod. Still having some issues getting the DRLs to work right, although I haven't put a whole lot of time into trying to run that to ground since I think the light conversion that was done on my truck might be interfering. The other issue is I can't get the TSR chimes working. Should be enabled, but no audible notifications if I'm over limit.
EONR24
Swag
United States
2024 Ford Maverick XL
So I have my 23 Hybrid XLT Lux, and decided to work on getting a few of the mods working on it while I'm here in the UK. Made some changes, and I've got the following mods up and running now:
  • Eco Coach
  • Speed Sign Recognition
  • Silent Mode
  • Lane Departure Warning (LDW)
  • Lane Keep Assist (LKA)
  • Driver Alert System
  • Seat belt startup screen removal
Made some adjustments for region as well, and enabled some tow settings that I'll loop back around to later once I tie a UK trailer electrical connector into the trailer harness (got the basic 4-pin, but trailers over here need just a couple more wires and also for turn and brake to not be the same light). Figured I'd post the complete list here so all the Mavericks that are getting imported over here have some reference to what works, and also for the FORScan gurus here to roast my work. Just waiting on the wiring manual to show up, then I'm going to look into seeing if I can come up with a less intrusive light-conversion mod for over here that isn't the hack and slash approach the local garage takes to make US vehicles street legal for the UK.
Mandatory disclaimer - Back up your AS BUILT settings before making any of the below changes in case you need to roll your vehicle back to factory settings.
Software: FORScan v2.3.58 Extended License / Hardware: OBDLink EX
ModuleSettingOldNewNotes
ACMDriver Restriction Configuration3 - Enable Speed Restriction1 - Disabled
BdyCMDRL include park lamps0 - Disabled1 - Enabled
BdyCMFront Turn Position Lamps Type0 - Turn Only1 - Turn and Position
BdyCMLeft Front DRL Lamp Usage0 - Not Used1 - DRL Only
BdyCMLeft Front Low Beam Usage1 - Low Beam and DRL2 - Low Beam OnlySwitchback Turn Signals installed, don't need lows acting as DRLs
BdyCMNumber of side doors0 - Two1 - Four
BdyCMRight Front DRL Lamp Usage0 - Not Used1 - DRL Only
BdyCMRight Front Low Beam Usage1 - Low Beam and DRL2 - Low Beam OnlySwitchback Turn Signals installed, don't need lows acting as DRLs
BdyCMSilent (Dark) Mode - Vehicle0 - Disabled0 - DisabledSet here if not using Silent Mode control function in IPC
BdyCMTrailer Outage0 - Disabled1 - Enabled
IPCChimes - Driver Belt Minder0 - Disabled1 - Enabled
IPCChimes - Mid Passenger Belt Minder0 - Disabled1 - Enabled
IPCChimes - Passenger Belt Minder0 - Disabled1 - Enabled
IPCChimes - Traffic Sign Recognition Overspeed0 - Disabled1 - Enabled
IPCCountry CodeUSUKThis changed what the speed limit signs look like with TSR enabled, also applies UK English to menus (i.e. tyres vs tires, bonnet vs hood, mls. vs mi., etc.)
IPCDriver Alert System (DAS)0 - Disabled1 - EnabledEnables Driver Alert menu option
IPCEco Coach Feature0 - Disabled1 - EnabledEnables Eco Coach View in MyView Menu
IPCECO Mode0 - Disabled1 - EnabledOnly seems to change ECO Icon?
IPCFrost Telltale (Below 5*C)0 - Disabled1 - Enabled
IPCGlobal Clock Setting0 - Disabled1 - EnabledEnables Clock Menu/Setting in Vehicle Settings Menu
IPCLane Assist0 - Disabled2 - LDW + Lane Keep AssistEnables Driver Assist. Screen (LDW enables just screen, LDW+LKA enables mode menu)
IPCLane Assist Haptic Intensity0 - Disabled1 - EnabledEnables Intensity Option in Lane-Keeping System Menu
IPCLane Assist Sensitivity0 - Disabled1 - EnabledEnables Lane-Keeping System Settings Menu Option
IPCLane Keep System Warning0 - Disabled1 - Enabled
IPCMenu - Chime0 - Disabled1 - EnabledEnables Chimes Menu in Vehicle settings
IPCMenu - Traffic Sign Recognition Activation0 - Disabled1 - EnabledEnables TSR Menu in Driver Assist. When system activated
IPCNavigation Speed Sign0 - North America1 - Rest of WorldChanged to read UK signs
IPCSilent Mode control function0 - Disabled1 - EnabledEnables silent mode on/off in vehicle settings
IPCSpeed Limit Information Function (SLIF)0 - Disabled1 - EnabledEnables TSR/SLIF Display at bottom of screen
IPCTrailer Reverse Guidance0 - Disabled1 - Enabled
IPCTrailer Tow Backup Assist0 - Disabled1 - Enabled
IPC (AS BUILT)720-13-01F100 0001 80AD9100 0001 804DDisable seatbelt popup while retaining seatbelt chimes/warnings
IPC (AS BUILT)720-13-020120 207D0110 105DDisable seatbelt popup while retaining seatbelt chimes/warnings
IPC (AS BUILT)720-14-012000 0000 005C1000 0000 0000Disable seatbelt popup while retaining seatbelt chimes/warnings
IPC (AS BUILT)720-14-020000 003DAll ZerosDisable seatbelt popup while retaining seatbelt chimes/warnings
IPMACountry7 - USA2 - UK
IPMACustomer Preferences - Driver Alert System - Personal 10 - Disabled1 - Enabled
IPMACustomer Preferences - Driver Alert System - Personal 20 - Disabled1 - Enabled
IPMACustomer Preferences - Driver Alert System - Personal 30 - Disabled1 - Enabled
IPMACustomer Preferences - Driver Alert System - Personal 40 - Disabled1 - Enabled
IPMACustomer Preferences - Driver Alert System - Vehicle0 - Disabled1 - Enabled
IPMACustomer Preferences - Lane Keep Setting - Personal 11 - LK Alert3 - LK Alert + LK Aid
IPMACustomer Preferences - Lane Keep Setting - Personal 21 - LK Alert3 - LK Alert + LK Aid
IPMACustomer Preferences - Lane Keep Setting - Personal 31 - LK Alert3 - LK Alert + LK Aid
IPMACustomer Preferences - Lane Keep Setting - Personal 41 - LK Alert3 - LK Alert + LK Aid
IPMACustomer Preferences - Lane Keep Setting - Vehicle1 - LK Alert3 - LK Alert + LK AidValue can be set by menu selection when configured in IPC
IPMACustomer Preferences - Lane Keep Support - Personal 20 - Disabled1 - Enabled
IPMACustomer Preferences - Lane Keep Support - Personal 30 - Disabled1 - Enabled
IPMACustomer Preferences - Lane Keep Support - Personal 40 - Disabled1 - Enabled
IPMACustomer Preferences - Lane Keep Support - Vehicle0 - Disabled1 - EnabledEnables LKS if phyiscal button not present (left stalk)
IPMACustomer Preferences - Lane Keep Support (LKS) - Personal 10 - Disabled1 - Enabled
IPMACustomer Preferences - TSR - Personal 10 - Disabled1 - Enabled
IPMACustomer Preferences - TSR - Personal 20 - Disabled1 - Enabled
IPMACustomer Preferences - TSR - Personal 30 - Disabled1 - Enabled
IPMACustomer Preferences - TSR - Personal 40 - Disabled1 - Enabled
IPMACustomer Preferences - TSR - Vehicle0 - Disabled1 - Enabled
IPMACustomer Preferences - TSR Chime - Personal 10 - Disabled1 - Enabled
IPMACustomer Preferences - TSR Chime - Personal 20 - Disabled1 - Enabled
IPMACustomer Preferences - TSR Chime - Personal 30 - Disabled1 - Enabled
IPMACustomer Preferences - TSR Chime - Personal 40 - Disabled1 - Enabled
IPMACustomer Preferences - TSR Chime - Vehicle0 - Disabled1 - Enabled
IPMADriver Alert System (DAS)1 - Disabled2 - Enabled
IPMALane Assist1 - Disabled3 - LDW + Lane Keep Assist
IPMARegion2 - North America1 - Europe
IPMATraffic Sign Recognition (TSR)1 - Disabled2 - SLOIF
IPMATraffic Sign Recognition Mode1 - Disabled2 - Camera Data Only
PSCMLane Departure Warning0 - Disabled255 - Enabled
PSCMLane Keep Assist (LKA)0 - Disabled255 - Enabled
SCCMLane Keep Assist (LKA)0 - Disabled1 - Enabled
Hey this is great info. I am putting together a Masterlist forscan spreadsheet / google doc. Can I include and link the info you provided here? Thanks. Did your Maverick come with co pilot 360 package? Also I believe all of the Customer Preferences can be controlled by MyKey or a menu in the Cluster as you mention in the notes.
RadioDoc
RadioDoc
Fairchild AFB, WA
Sure feel free to include it. I do not have Copilot 360. That's the one package I would have wanted to add on if I had the opportunity, but my truck was already on the lot when I got it.
EONR24
Swag
United States
did the 2 door to 4 door change do anything? also was on 2 door from the factory?? Also what parts have you installed to enable the lane assist ?
RadioDoc
RadioDoc
Fairchild AFB, WA
If 2 door to 4 door changed anything, I haven't noticed. Was set to 2 door from the factory. I haven't installed anything to enable LKA, that was 100% just a FORScan mod to get it running. I want to get the switch with the button for it, just don't have the time to put towards it right now.
Panther City Outdoors
Tejas
www.youtube.com
I used to live in Ireland and Scotland, I bet the Mav is perfect for there. I know that my UK/Irish youtube subscribers really like the little truck. What kind of responses/comments are you getting there? thanks
RadioDoc
RadioDoc
Fairchild AFB, WA
Where I live is basically Little America, so not too many head turns other than "it's a hybrid?" I'm also out in farm country so there are Rangers and Navaras all over the place and the Maverick just blends right in. I will say that where the Maverick really shines is driving around the villages where you're not putting the speed up over 30-40. The hybrid system kicks in and gas mileage skyrockets. Getting out on the A roads you're still doing 10-20 mpg better than anything comparable in size, and towing is a breeze with it.
