Ford Performance Intercooler
DentSurgeon
Jay
New Hampshire
2026 Maverick Lariot
I have a 2026 Maverick 2.0. I got the ford performance intercooler. Tried to install it today and it looks like the active shutter assembly has the radiators mounted to it. Has anyone done the swap to the ford performance intercooler? The install instructions from ford were pretty vague on how to remove the actual intercooler. Im hoping the radiator and condenser don’t have to come out. I ran out of time and had to put the truck back together. Any insight appreciated!
NycGoose
Devin
Cooperstown
Maverick, tacoma, bmw 325 89
I’m getting my suspension changed and then want to do the same upgrade myself. Hoping its not too hard of a job
Grammaton
Ross
Covina, CA
2023 Ford Maverick AWD Lariat BAP 4K CP360+Assist
You have to remove the entire front bumper support which is 8 nuts and 2 bolts after you remove the headlamps. Also disconnect MAP sensor from Passenger side Intercooler hose before disconnecting intercooler hoses. Make sure to unclip the hood release cable beforehand from top of shroud/shutter then you can remove the whole shroud and shutter system after squeezing and pushing in the upper radiator plastic retainers on each side of the top of shroud/shutters after removing the 4 bolts from the lower support bar.
The Radiator and Condenser aren't removed but you do have to release the plastic clips at the top on each side holding the condenser, so condenser can move a bit up and out to make more room to remove the OEM intercooler.
Chops
Lobo
Ford Dealer installed mine. No extra parts required or modifications - “plug & play”. I’m assuming they followed the instructions per Grammatron’s attachment above. Removing the grille & bumper seems like a pain - but worth it!
Ford Maverick Ford Performance Intercooler IMG_0468
SteeleMech
2023 Maverick
How much did they charge you?
Automan21
Mel
‘23 XLT Eco AWD 4K Tow
I just took the bumper off and used the procedure the other intercooler companies follow. Cut and install done. Wasn’t taking that whole carrier off.
DentSurgeon
Jay
New Hampshire
Kim
so after pushing in upper radiator clips the whole shroud assembly will slide out?
FERALMAVERICK
Brent
2025 maverick tremor
Kim
YES with a little finesse it will separate the 2 tabs are plastic so be careful , once you do that it pretty straight forward
Chops
Lobo
Was quoted 3 hours labor by service guy @$199/hr.
I agreed to pay for 1 hour since I was getting my radiator replaced under warranty and the only extra work required would be unboxing the intercooler (5 mins).
I like to DIY - but was happy to pay the $199 and avoid the front end disassembly. Dealer did a great job lining everything back up.
They even had to partially remove my Mabbet fender flares & reattach. Did not charge me for the new 3M tape or adhesive promoter that noted in their job comments.
SteeleMech
2023 Maverick
Yeah, I have the same Fender flares and was weighing to do it myself or find a mechanic that could do it
Tbone289
Bumper/grille removal isn't that bad. I must have done it 20 times trying to get my fog lamps aligned right. Well, once to mount them and several more partially on and off for alignment.
Chops
Lobo
I bet the 20th time was easier than the first! Learning Curve is both a blessing and a curse:)
DentSurgeon
Jay
New Hampshire
Great, I followed the ford performance instructions, and it just seemed like it wouldn’t come out seperate. Had it all apart and put it back together. Now that I look at instructions again I may have skipped releasing the 2 radiator clips. I will give it another shot. Thank you
also I couldn’t get bumper support off because the part of the shroud was inpront of it, so it prevented me from pulling it completely off, am I just loosening it to allow the shroud to slide out?
DentSurgeon
Jay
New Hampshire
So I just finished installing. Did not have to remove radiator and condensor. I basically tilted the bumper support and shroud together to the floor, after unlatching the 2 radiator clips. I did the job alone, highly recommend another set of hands, it was a bit$h to get it all back together and lined up. Hardest part was getting the radiator rubber bushings back into the bottom of the shroud housing. Doing it alone took me about 2.5hrs. Thanks for all the input.
Ford Maverick Ford Performance Intercooler IMG_4453
Ford Maverick Ford Performance Intercooler IMG_4451
FERALMAVERICK
Brent
you have to get all the support bolts out other wise you wont be able to separate the shroud enough to get to the inter cooler , i have a tremor and it does(nt) fit so and i was being lazy and didn't take the tow hooks from the frame rails so it was still kinda connected . but had enough slack
