For those with battery, charging and Auto/Start/Stop problems...
Nw_adventure
Salt Lake city
After getting my battery exchanged, I started to get dash error/warning messages about a charging system problem. At the dealer this morning we found one of the positive battery lugs was loose- Its one that attaches to the harness and in that you can change the battery without even touching this nut but it was loose. Tightened and everything checks out ok now with diagnostics.
Attached a picture for reference.
Ford Maverick For those with battery, charging and Auto/Start/Stop problems... Battery post
AltoBAP
Jefferson
Metro Detroit
2020 Ford Fusion SE 2.0 AWD
That yellow paint stripe on the other bolt indicates it had an additional quality check performed, most likely to verify torque.
Perhaps they should refocus their efforts.
Nw_adventure
Nw_adventure
Salt Lake city
Yep lug without that stripe just left to rot- lol- A/S/S works fine now even in cold weather-
Haha48
Scott
Canada bc
Found nothing for the 4th time in there won't charge the battery so starts stop won't work. Won't go over 12.6 no mater how long its on for
Ford Maverick For those with battery, charging and Auto/Start/Stop problems... 16690716334976830646469993877602
Ford Maverick For those with battery, charging and Auto/Start/Stop problems... 20221027_143800
Nw_adventure
Nw_adventure
Salt Lake city
Just curious have u done the battery/charging system reset ?
Mabcim
Rochester, NY
Nw_adventure
Nw_adventure
Salt Lake city
I wonder if you did not really need a battery, and it was just this all along?
My Ford tech and I think this as well but I got an upgraded battery out of this small hassle -)
Nw_adventure
Nw_adventure
Salt Lake city
Sadly I have to update this post- After having the battery replaced, main connection harness tightened and the entire fuse box replace, Auto/Start stop which has not worked for two months and now the truck has entered deep sleep - This is an Ecoboost which is driven normally- What is going on with Fords charging systems or lack thereof ?
Ringo
AR
1953 MGTD, 1953 F100, 2022 Maverick
We may never know……….
