Fog lights for Maverick ?
Dad
Dad
If you want something cheaper but are still mounted in the grill (I hope, there is enough height between the grills) you can get these from Amazon: www.amazon.com/dp/B07DPN5B8V/ref=cm_sw_em_r_mt_dp_CZQ9S0GP65C7YFG86Q4X?_encoding=UTF8&psc=1 for little more watts get this www.amazon.com/dp/B097R8BZLV/ref=cm_sw_em_r_mt_dp_F2DB68TKYH0BAADMT9HJ?_encoding=UTF8&psc=1
Yeah, these are cool, but the problem is that you have to cut away one of the struts to get it to fit. Less than 5" between struts.
fossil
ernie
ohio
I'm gonna go with Diode Dynamics SSc2 SAE 2 inch fog lights. Should be able to tuck them in some where. Clear white with amber back light.
Ford Maverick Fog lights for Maverick ? SS2
GPSMan
Many
I have not pulled the trigger yet. But these are in my cart right now. A pair of these:
Ford Maverick Fog lights for Maverick ? 36B9352F-DD97-467C-BB1E-19A344DF056D
Centered in the cut-outs. No tow hooks available for the hybrid. May as well make use of the space.
Ford Maverick Fog lights for Maverick ? D19603B2-1774-42FA-8B8B-7CFF39E12DDA
Dad
Remember, there's only a 2 & 1/4" clearance between the grille slats. These look to be about 4" in height
fossil
ernie
ohio
these are 2 inch lights, get those eyes calibrated :D
Product Dimensions (in): 2H x 3.3W x 2.4D
Dad
No doubt these will fit in the bumper pods(?). Question is how to mount them securely and angled.
Has anyone looked into the possibility of flush mount lighting?
https://a.co/d/6iSZIh1
Dad
Oh. My mistake. Thank you. Now you have my interest.
A link, if you please?
fossil
ernie
ohio
MaveRican
Luis
Riverview FL
www.instagram.com
White XLT
No worries. Will do. Thanks.
Limited-time deal: Nilight Led Light Bar 2PCS 6.5 Inch Amber 120W Spot Flood Combo 12000LM Waterproof Triple Rows Fog Lights Led Off Road Lights with 16AWG Wiring Harness Kit-2 Lead, 2 Year Warranty https://a.co/d/i4DiCHK
ShadowBlack XL440
Robert
Northern Ohio
While the led headlights do a fine job of lighting up the road, I'm considering auxiliary lights to brighten up the road more directly in front. Sure, fogs, but more so for spotting road hazards close up. Anyway, I'm thinking of fitting them into lower section of the front grille. Limited space unless you cut one one of the support struts and I'm not too keen on that. Need a light that is under 5 inches wide and about 2" tall to fit. I've searched Amazon, but perhaps someone here has some experience and suggestions.
I like these dual color flat beam LEDs, I just have not had a chance to figure out a good mounting process yet.
https://www.amazon.com/dp/B09P341PN...coliid=I6GA3ZDP8S6O4&colid=2Y6DSIFC1J9N9&th=1
Ford Maverick Fog lights for Maverick ? 1667763246780
GPSMan
Many
I've looked around for 2 week.
This is FOR SURE the best deal on the internet.
Dad
Thank you very much. I've seen a couple of flush mount units that would fit neatly in the space I mentioned. Only problem is how to mount them. Nothing but air directly behind the grille slots. These would work on the bumper with some modification to get them to align properly.
