Flowkottu Retractable Tonneau Cover review
VrtualOtis
Derek
Seattle, WA
2024 XLT Hybrid - Cactus Gray
I installed this about two weeks ago and just got around to taking pictures so I thought I'd share my impressions of it. Especially since it's currently on sale at Amazon.
I liked the idea of a retractable with the t-slots to eventually add some Tuwa adjustable bed rails and a rooftop tent. I don't do a lot of deep overlander stuff but up in Washington there's plenty of places I can get the hybrid to that will make good use.
Installation definitely needs two people. Instructions are not the best, and there seems to be a fair amount of extra parts and stuff they didn't show when or where to use them. Took us about an hour to get the tonneau assembled and on the truck, but finding the right spot and getting it adjusted took at least another hour, and even then I had to go back and make some more adjustments a few days later when I realized that some of the adjustments I made to make the cover retract smoother caused the tracks to get out of alignment, leaving a gap that would allow the top to pop open and retract while driving, and also let a ton of water in. Now that it's adjusted, I'm liking it quite a bit.
One note, I did not attach the latch onto the tailgate to allow it to lock closed. I didn't want to bolt it on and with the tailgate locked and closed, you can't access the strap to disengage the side locks anyway. Plus, where I finally got it aligned on the bed where everything operated smoothly and I could get the weather seals set, I didn't have room for it.
Pros:
-Retractable, slides open smoothly and just pull the strap on close it.
-Has a midway latch that allows it to open part way and secure in that spot.
-front drain hoses are set up well to pop into the drain holes in the bed (similar tonneaus I saw people had to get creative to make the hoses drain properly)
-once adjusted, it seems to hold out water very well. The bomb cyclone hit and blew down sections of my fence, my neighbor had a tree fall on her house, but when I opened the tailgate to load supplies in the bed, it was bone dry.
- has t-slots to add rails, etc.
- hundreds, even thousands less than most other retractable tonneaus
-looks great in my opinion
Cons:
-wonky instructions
-kind of a pain to install (literally, my knuckles looked like hamburger by the time I was done) - some of this was probably just me, I was cold and wet when installing it so I was kind of rushing, but getting it fitted and adjusted was quite a task
-I don't like how the rain seals sit/fit. The one against the cab, it basically folds up against the back window. It creates a trench where lots of debris builds up (see the pictures) and covers a good 2" of the bottom part of the window. The way this seal is, it seems like the entire cover is supposed to be about an inch and a half further away from the cab, but doing so prevents the cover from closing, as the latch underneath would hit the tailgate before getting to the latch point. The side seals tuck underneath the tonneau rails and it was hard to get them to stay out when moving the whole thing into place. Luckily I had just installed window visors on my wife's car and it had the perfect tool for manipulating it out from underneath.
-in order to install the locking button latch clasp, you have to have the entire assembly another 1/4" closer to the cab of the truck. Doing so puts the rain seal straight vertical and the overall fit on the bed didn't look right to me. Between that and the need to screw it into the tailgate, I chose not to install it. As mentioned, it still locks into place and I don't believe it can be opened without opening the tailgate anyway. The latch is opened with the pull strap that sits in the bed while closed.
-rear drain hoses cover the top rear tiedowns (see picture). I tried to use the upper drain holes, but it still kind of blocked the tiedowns and it put the hose at a more severe angle and caused some kinks. So while the front are well done, the rear not so much.
EDIT to add, current price on Amazon as of 11/21/24 is $675
Ford Maverick Flowkottu Retractable Tonneau Cover review 20241121_094348
Ford Maverick Flowkottu Retractable Tonneau Cover review 20241121_094130
Ford Maverick Flowkottu Retractable Tonneau Cover review 20241121_094137
Ford Maverick Flowkottu Retractable Tonneau Cover review 20241121_094148
Ford Maverick Flowkottu Retractable Tonneau Cover review 20241121_094151
Ford Maverick Flowkottu Retractable Tonneau Cover review 20241121_094227
Ford Maverick Flowkottu Retractable Tonneau Cover review 20241121_094204
Ford Maverick Flowkottu Retractable Tonneau Cover review 20241121_094409
Ford Maverick Flowkottu Retractable Tonneau Cover review 20241121_094359
Ford Maverick Flowkottu Retractable Tonneau Cover review 20241121_094331
Ford Maverick Flowkottu Retractable Tonneau Cover review 20241121_094308
flyswatter
Macon GA
2024 Ford Maverick Lariat, 2020 Lincoln MKZ
Hell of a price for a retractable and looks good too. My only gripe is the loss of 5 inches or so of bed space (that being a big guess on my part).
VrtualOtis
VrtualOtis
Derek
Seattle, WA
Yeah, roughly 5"-6" or so. That was a drawback to me as well, but the tri-folds I was originally looking at, most lose even more while driving with them open. The only hard rollup I like was double the price of this thing. I plan to add a board with fork mounts in the area under the roll up cannister, it fits perfectly so I can open the cover and load two bikes. I made it similar to the bed dividers I've seen here where it folds in the center so I can slide it in, fold it open, and lock it into place.
flyswatter
Macon GA
Yeah, the drawback of my Tacoma's tri-fold was the complete loss of the view through the rear window when fully opened.
Nuclear One
Lake Havasu City, AZ
23 FX4 Lariat 2.0 EB
I bought mine on Amazon and got the racks included..... ~$800
$800 with rack included
Ford Maverick Flowkottu Retractable Tonneau Cover review 20240814_161241
VrtualOtis
VrtualOtis
Derek
Seattle, WA
I didn't even see that as an option when I ordered! Or is that a SyneticUSA cover with racks? I see that one, it's currently $1250 on Amazon. The Synetic USA was the one I was originally going to get but it is currently just shy of $1k on Amazon for the cover by itself, this Flowkottu was 2/3 the price of the SyenticUSA
riparian
Virginia
2024 Maverick XLT hybrid
Really thorough and helpful write up, Derek. Appreciate the effort.
Do you have a rough idea of the weight? I don't see it in the product info on the Amazon page.
VrtualOtis
VrtualOtis
Derek
Seattle, WA
If I recall the delivery notice said the package was about 80lbs. There's a thin sheet of wood for rigidity in the box, plus tools and excess parts we didn't use, so I would estimate about 70lbs.
riparian
Virginia
Thanks!
WolfWoosh
Michael
Gold Bar, WA, USA
2024 Ford Maverick Lariat Shadow Black w\ Blackout Package
@VrtualOtis Thank you for this review. Just got my Maverick 12-1-2024. So only 5 days ago. Also in WA and glad to hear about the water sealing ability. This one is definitely on my list now. I might want to trim that front rubber seal a bit before I install
VrtualOtis
VrtualOtis
Derek
Seattle, WA
I think you'll be happy with it. I agree, maybe trim it in half would be perfect. Or you may have better luck positioning it than I did. I'm changing out the drop in bed liner on mine, I suspect it will fit much cleaner without it.
zacatac
Pittsburgh, PA
'25 Maverick LOBO
Do you have, or would you be able to take, measurements of the box that it retracts into?
I was considering a hard cover to replace my canvas, but I need basically all of my bed length at times for work tools in different sized pelican cases. I'd have to make sure I could Tetris everything in before committing to this style of a cover.
The dimensions are on Amazon.
Don't forget about the track that runs along the top of the bed.
Ford Maverick Flowkottu Retractable Tonneau Cover review IMG_20241206_190420
zacatac
Pittsburgh, PA
'25 Maverick LOBO
Thank you!! I didn't see it in the product pictures and when I scrolled through the listing I obviously missed that part!
I'll be doing some measuring and testing toolbox configurations tomorrow now.
