It's almost as though the hood wasn't designed structurally for something that the truck didn't come equipped with.
Hey, love that profound sarcasm!!!It's almost as though the hood wasn't designed structurally for something that the truck didn't come equipped with.
I did check. It's very minimal. Maybe some brands use more powerful struts. The ones I have, on the mav, do not lift the hood, rather they just hold it open. That's all I want from them. The hood won't be opening and closing that often like those going to car shows every week.Have you checked out how much flex in the hood there is at the hinges? It’s lifts the back edge of the hood off of the mating surface
It really doesn’t have anything to do with the struts themselves, but of the free hanging weight of the unsupported hood. And also the load applied to the hinge mount when you close the hood. A gap appears between the hinges and the hood, backside of the the hinge.I did check. It's very minimal. Maybe some brands use more powerful struts. The ones I have, on the mav, do not lift the hood, rather they just hold it open. That's all I want from them. The hood won't be opening and closing that often like those going to car shows every week.
You might want to consider that your Mustang hood is steel and the Maverick hood is aluminum, so results may vary.My mustang does the exact same flex, just checked. It's been through hundreds of cycles and 184000 miles of vibration in 18 years without issues. And my hood has a shaker hole and two heat extractor vent holes cut into it long ago. I'm not worried about it.
My 2009 Mustang is aluminum. Same report, no problems.You might want to consider that your Mustang hood is steel and the Maverick hood is aluminum, so results may vary.
Sorry, but it is aluminum and I know that because I cut the holes in it myself. Just saying it's not the problem people make it out to be. My opinion and observations from my own experience.You might want to consider that your Mustang hood is steel and the Maverick hood is aluminum, so results may vary.
I think some on here are overly defensive about their decision to use struts. I never said there was a problem, just a consideration of steel vs. aluminum, not knowing that his Mustang was aluminum also. I don't use them simply because I don't need or want them.My 2009 Mustang is aluminum. Same report, no problems.
I think some on here imagine problems that don't exist.![]()
While reading about the Maverick on other sites, there have been issues with installing struts, that it may cause miss-alignment of the hood. There were ways to solve the issues, but I never paid much attention to it, because I had no desire to install them. I would search installing hood struts, and read about it.I recently installed one of the hood strut setups.
Now I’m noticing that the hood on the Maverick is in no way reinforced at the hood hinge mount, so there is a lot of flex when you open the hood.
My concern is that we will start developing cracks or bending at those mounting points.
Has anyone at this point had any cracking or bending?
The only way I can think of to help distribute the load of the hood hanging out there is to make and bond to the hood some reinforcement plates.
The best thing would be if one of the oh so many companies selling these products would produce and sell such a thing.
