Flex Bed 12v power on passenger side not driver side [SOLVED]
wishtx
dk
texas
2025 Ford Maverick XL
Hey yall, been trying to track down why the 12v Flex Bed power source is only present on passenger side of bed and not driver side. They’re on the same circuit, already checked the engine bay fuse, and when I installed the Mabet drivers side body cavity cover I checked physical connection of the plug, appears to be g2g. Any idea why the passenger side is only one getting power? ‘25 Maverick XL AWD EB. Thanks!!
BlueSpec1
Gene
wishtx
dk
texas
Well, guess I’ve got another fuse to eyeball. Everything googled indicated only one shared fuse, albeit I admit I didn’t pay attention to what years those posts referred to. I’ll take a look and see what I find, thanks!
Quest
Ford split it into 2 circuits in 25
wishtx
dk
texas
Was indeed the second fuse. Will be saving that link above. Thank yall!
**Edit**
Figured I’d attach an image of what I ended up able to install after the fix. Four switch panel, first switch set up with inverter to power 110v outlet, USB-A/C port, 12v port and three remaining 12v switches for any future use found
Ford Maverick Flex Bed 12v power on passenger side not driver side [SOLVED] IMG_1384
