Fender Flares will mess your paint up
Stock411
HI
2022 Ford Maverick XLT Hybrid
Warning: Fender Flares will mess up your paint and scratch it up.
Rocks also accumulated in the pocket of the fender flare causing chipping and scuffing.
Fender Flares scratching paint aren't a uncommon thing, in fact it is common.
I was fortunate enough to catch it in time and minimal damage occurred.
These were on the truck for a year and no off road usage or anything.
Ford Maverick Fender Flares will mess your paint up IMG_0931
Ford Maverick Fender Flares will mess your paint up IMG_0925
They looked great, but I think it its not worth it.
Ford Maverick Fender Flares will mess your paint up IMG_0941
There's products like fender flare tape from sites, however that doesn't stop the dust and pebble/rock build up inside the pockets of the flares.
Big Kahuna
WA
Same thing as the ford mud flaps that didn't have enough of a gap and rubbed the paint. Glad you caught it before it got too bad.
OTACORB
DAB
Central, Louisiana
Those are the bigger fender flairs. Did you use the sealant or did it not come with it. The smaller flairs come with some sort of sealant. Not sure if that will prevent what you are referring to.
Stock411
HI
No sealant came with it but it did have a thick rubber gasket in between the hard plastic and paint surface.
OTACORB
DAB
Central, Louisiana
Well I am glad you caught it? What made you remove it?
ZachSD
Zach
San Diego
2004 GMC Canyon 3.5L (159k)
That's painful to look at. Appreciate the warning. I feel like these trucks will all need new paint within 5 years.
Maverickman74
Shane
Maui HI
Yeah thats fender flares for ya. Even the ones with factory flares or black plastic cladding. Take the plastic off any of em and you will see roughed up paint, dirt, rocks, salt, you name it. Plastic body cladding protects your paint and sheetmetal from damaging it by slowly rotting it underneath.
UberGadgetFreak
Mt. Holly, NC
03 Marauder, 21 Bronco, 22 Maverick
I have the AirDesign ones on my FE. They did come with polyurethane sealant, but the Bushwackers did not (have those for my pending Tremor). Today, the best method to prevent this sort of thing is to use some paint protection film underneath them, or go old-school and use some sealant around all the edges like caulking a window (I did this with mine with clear silicone). The only thing is to leave a small air hole somewhere so temperature changes don't work it loose over time.
mav_kev
PA
Mav
Fender flares also mess up the look of the Maverick, but that's just me.
Bsoute00
Oklahoma
06 F250, 21 Bronco Sport, 23 Maverick XLT
The only way around any of this is to either apply or have applied ppf prior to installing anything that could contact the paint. This even goes for bug/hood protectors.
With the paint on our truck, the truck should come with a roll of Paint Protective Film from the factory. :)
2003VETT
Shawn
NJ
2023 Maverick Hybrid Lariat
I used black caulk around the edges of mine on my GMC. looked great and removed them 3 years later when the lease was up and gave them to a friend. Not a scratch underneath. Took an hour or so to remove the caulk, but was worth it.
