FDU Oil Replacement Problem
Heyspike
Hudson Valley NY
www.johnryan.us
C5 - Fairway Green, SIlverado
OK, ever have a day where half goes right and the other half doesn't?
Well I did my RDu oil replacement no problem. I went to do the front and for the life of me cannot
find the drain plug! Here's a few photos, You can see the 8mm socket in the fill nut.
I jacked up all four corners of the truck for better access.
Also I broke 2 skid plate bolts putting them back in, I need the part number if anyone has it.
Thought they would be stronger than they were, I just cranked them down a bit.
Ford Maverick FDU Oil Replacement Problem 20260310_110033
Ford Maverick FDU Oil Replacement Problem 20260310_125007
Ford Maverick FDU Oil Replacement Problem 20260310_124952
Ford Maverick FDU Oil Replacement Problem 20260310_125013
BlueSpec1
Gene
How To: Maverick Tremor PTU oil change
"The Tremor PTU is different from the FX4 or the AWD.
First the bad news, there is no drain plug, The Good news is you don't need one because you can drain the oil out of the cooler attachment point."
Cancunbadlands
Cancun
Cancun
There's not such a drain plug for the FDU
available with the Tremor Package
BlueSpec1
Gene
