Fan Speed with AC
Fcarl
Frank
Taber,Alberta,Canada
2024 Maverick Hybrid , 2014 Mustang Roush Stage 1
2024 hybrid, i drive 35 miles to city to shop, on return drive home with the AC on i have the fan speed on 2 , approximately 3/4 home the fan speed increases dramatically without me touching or adjusting anything , i turn it to 1 but it still is at a higher speed , its like i cant control the speed, just about have to turn ac off, about 5 miles later it goes back to normal ! comments please
Sure you don't have Auto pushed also?
In which case your selection of fan speed is actually a range you might say, where the auto can adjust the actual speed within that range.
or....
You also could be getting the effect of high humidity reading and so it's running the AC a bit more to confirm you won't have an issue.
Is it louder because it's actually defrost vent routing also, not your selection of say just upper?
or...
You have some glitches in some modules.
Ever left the AC engaged when you turned the truck off on park, and you still hear a fan running on exit, maybe later on short return?
May need that ACCM upgrade.
Got any active recalls for any systems?
Sometimes those module upgrades take care of other little issues that weren't upgrades, but TSB's or SSM's if you had the specific issue. That may apply.
For sure figure it out to exactly get it to kick off, what conditions are required - or a dealer visit will likely be a waste of time.
Fcarl
Fcarl
Frank
or....
or...
Not on Auto
HAL will decide what fan speed you need.
Ford Maverick Fan Speed with AC 20250701_082410
Ford Maverick Fan Speed with AC 20250701_083056
Real life suggestion.
Put your a/c in auto mode, select one of three auto mode fan speeds, select your temperature and forget about it.
MYMAVXL
Chuck
Virginia
You are not alone…mine does the same thing. Not on Auto, usually on a run longer than an hour or so. It just cranks up the AC. There are lots of theories, but the dealer can’t figure it out, and I’ve learned to live with it. I usually hit the defrost button to redirect it so it doesn’t blow away the passengers…
AutobahnSHO
Will
S.Carolina
Maverick, Miata
Probably detecting humidity and trying to keep that at bay.
MYMAVXL
Chuck
Virginia
It's an advanced technology feature for your comfort and convenience.
Ford's R&D is sure you'll love it.
Yup…I’ll be sure to tell them how super convenient the Auto-Freeze feature is. šŸ˜µā€šŸ’«. I think the de-humidify idea is probably correct…I just wish it didn’t crank up the fan so much….
The Real Maverick
Jack
It also cranks it down if your phone rings. šŸ¤·šŸ»ā€ā™‚ļø
MYMAVXL
Chuck
Virginia
So when my wife is in the truck I’ll have her call me to fix this…. That’s a riot!!!
