Extreme gas mileage using non ethanol fuel
ZABSMAV
Utah
2023 Maverick Lariat Hybrid
Yes, ethanol-free (E0) gas typically provides better mileage. Drivers generally see an improvement of about 3% to 4% in miles per gallon (MPG) compared to standard E10 (10% ethanol) fuel. [1]
While users on platforms like Pilots of America agree that you get better range, opinions on Reddit's Mechanic Advice indicate that the higher cost of ethanol-free gas often offsets the efficiency savings. [1]
Why the Difference?
  • Energy Density: Pure gasoline packs more energy per gallon than ethanol. Ethanol contains about one-third less energy, so your engine has to burn more volume of an ethanol-blended fuel to produce the same amount of power. [1]
  • Engine Tuning: Many modern vehicles are designed to efficiently run on E10, so the difference in MPG might be less noticeable. However, older vehicles and small engines often run more efficiently and avoid fuel-system corrosion using ethanol-free gas. [1, 2, 3]
Is it Worth the Cost?
It depends on how you use your equipment:
  • Daily Drivers: The cost difference between regular E10 and premium ethanol-free fuel is usually larger than the 3% to 4% fuel savings you get at the pump. [1]
  • Small Engines: It is highly recommended to use ethanol-free gas for lawnmowers, boats, chainsaws, and stored vehicles. Ethanol attracts moisture over time and can corrode fuel lines in infrequently used equipment. [1, 2, 3, 4, 5]
To see if it makes financial sense for your specific vehicle, compare local fuel prices and manually track your MPG for a few weeks on both fuel types. You can find local stations that sell pure gas by searching the Pure-Gas.org Database. [1]
You lost me with the quote from Reddit's Mechanic Advice that said "the higher cost of ethanol-free gas often offsets the efficiency savings".
The difference in price, where I live, for 88 octane ethanol-free Clear Gas is only 10 cents more than 87 octane gas with ethanol.
The lower compression of the internal combustion engine in a Ford Maverick hybrid, in normal around town driving, does not need anything higher than the 87 octane. According to Ford, 87 octane is standard for normal use.
Our 2023 has just the 2K tow but we will likely never tow with it since we have a real truck for truck towing needs, so the recommendation to emrun higher octane (91) while towing wouldn't apply to us.
Also won't waste money on the so-called "top tier" fuel. The ones that advertise that here are much higher per gallon than anywhere else.
Maverik Adventure Stops are extremely popular out west and are expanding further east. They are always packed with cars gassing up so their gas is always fresh. For the extranmiles per gallon for such a tiny difference at a fill up, we'll stick with the ethanol free gasoline.
I'll let our dealership shop tell us if it needs any additive when we have the plugs checked. Highly doubt it will.
kevinmccune
kevin
BATH CO ,VA
2022 XL maverick
our 88 is 15% ethanol and its usually30-40 cents cheaper a gallon( what kills me is the subsidies the big AG companies get at taxpayer expense)
MavStangVa
Here, There, and Everywhere
2024 LARIAT AWD
I passed the closest station to me Sunday that has ethanol free gas. It is 15 miles away. Regular 87 octane, 10% ethanol was 3.49/gallon. Ethanol free, they did NOT list the octane which would make me skeptical, was $4.99/gallon. Prices vary widely. If I could get pure gas for 10 cents more I would if it was top tier. The point to using Top Tier is that manual actually says " We recommend Top Tier detergent gasolines, where available to help minimize engine deposits and maintain optimal vehicle and engine performance. " Wawa is very popular here, cars waiting in line at some locations, same with Sheetz. Their gas SUCKS. But hey it's usually a nickel/gallon cheaper so people buy it. I have found Shell works best in my Ford trucks going back to 1992 when I bought my Ranger. Other brands like Exxon Mobil Sunoco are fine, even BP but I prefer Shell.
ZABSMAV
Utah
You do know that the auto manufacturers have a financial stake and incentive to "encourage" use of so-called "top tier" fuels. And it isn't to ensure your engine somehow stays "cleaner". More like their bottom line stays more profitable.
ZABSMAV
Utah
Maverik Adventure Stops only charge 10 cents more between 87 octane regular and 88 octane Clear Gas ethanol free gasoline. The prices on the pump prove that. Don't understand why your area charges that much more for ethanol free except it might just be that in the corn belt areas they price ethanol free gasoline much higher to keep the farmers happy.
Ford Maverick Extreme gas mileage using non ethanol fuel 20260618_180432
MavStangVa
2024 LARIAT AWD
You have made that point many many times. Also the difference between 85 and 91 in your area is much lower.Yet it just seems impractical for me to drive to Utah to get my gas. It's great you can get it so cheap but most of the rest of us can not. Therefor the gain in mpg does not justify the cost. If someone prefers 100% pure gas that is fine with me but you can not argue it is not much more based on a limited availability. Here we do not have 85,87,91 we have 87,89,93 octanes. Virginia is NOT the corn belt. Virginia is ranked 25th for corn production. Sorry I don't believe the gas stations charge more for non-ethanol to keep the farmers happy. Gas stations operate to keep stock holders, owners happy.
ZABSMAV
Utah
Exactly. You hit the nail on the head. The same thing that was happening in the home solar business as well as the industrial solar plants. As soon as the artificial subsidies by taxpayers were taken away, they were not at all cost effective, and the companies quickly disappeared.
