javendan
2022 Alto BlueFord Maverick Hybrid XLT with Lux
Hello fellow Maverick owners / fans!!!
Here is a picture of our hybrid with the Elevate CS Rack.
If you're interested in anything Maverick check out RealTruck and get a hold of Alex here on the forum!
I did loose a few MPGs on my daily commute... 37 from about 41 over 40 miles one way and they are at the lowest height.
Luckily, the towers are easy to remove and add once everything is set up.
The main use for the rack will be for SUP duty... no pics of the SUPs at this time :)
Ford Maverick Elevate CS Rack installed IMG_9682
Joel
Truck2
jeff
usa
toyota highlander hybrid
Darn, 10% drop. Btw, what things do you use this setup for?
thank you
Doug Wildman
Doug
Orlando, Florida
2021 Tesla Model 3, 2022 Maverick
Truck2
jeff
usa
My bad...was guessing surf boards
Gvmumbral
Gerardo
Pasadena, CA
Honda Element
Joel
You lost MPGs with just the racks? nothing on them or top of them? Just for having the racks empty? like in the pictures?
dang!
Big Kahuna
WA
I haven't noticed a difference in MPG with mine (Ecoboost). I also got a good deal from Realtruck and am enjoying the racks. I also have the Pro X15 Tonneau which wasn't fitting right but got it working now (when mounted with the cs rails you remove the seal and replace it with a thinner CS rail one). I got the racks for paddleboards, kayaks, cargo box for camping.
I do a lot of surfing - below is a pick after my first SUP surf session with the racks.
They have a really good rubber strip that goes along the top - it keeps anything from sliding. Was very impressed with that in particular. Even 2 x 4s etc you likely wouldn't have to worry about them sliding much after strapping them down.
Hammer
Easton PA
2009 VW GTI
I also rate the Elevate rack/rails a thumbs up. Also received a great deal from Alex at RealTruck.
Ford Maverick Elevate CS Rack installed 4725FE6C-C908-41D5-B2E1-53DB18CBCDC4
pickupdude
Los Angeles
Maverick XL
damn! those look great and the perfect height. will definitely pick those up whenever i get my truck. what is the best tonneau cover with those?
pickupdude
Los Angeles
Maverick XL
also. since you guys surf. think i could fit a 6' diagonal under a tonneau cover? even if it has to ride up on the wheel well?
Big Kahuna
WA
Scout
Washington
2025 XLT AWD hybrid azure grey
Joel
Question, I’ve been looking at the Yakima HD rack due to the idea I can remove the setup when wanted. Can you fully remove yours? Thanks!
mw_maeve
Michael
Los Angeles
2022 Maverick XL
Joel
You lost 4 MPGs just because of those racks? 🥴
Realtruck
Diamond Sponsor
Realtruck
Ocala FL
Hey everyone!
Im, the Alex referred to as reaching out for special pricing!
This rack will work with any flush mount hard folding/rolling cover and any flush mount soft roll-up
These bars are fully able to be put in any position along the bed and are fully removable if you choose. They also come with tie-down cleats if you buy the rack and rail combo, needed if you dont have a cover like the RetraxPRO/ONE XR that has t-slots built-in
Reach out to me and I can get you a great deal on this AND a cover to pair it with if you don't have one already!
Big Kahuna
WA
Yes - pretty easy. Two nuts to be removed on the base of each and you can remove them as one piece or 8 nuts and you can take it off each one in three pieces. Here is a good video showing how they go on and off.
