Drive Modes not changing
dfitz
2024 Maverick Lariat 2.0L EB
When I press the drive modes button, it doesn't change on my 24 EB Lariat. Anyone else had this issue?
Ozarkbeard
No drive mode problems on my XL, other than the button should be on one of the steering wheel stalks and not down on the console.
RR - All the way
GA
Do you mean the drive mode button that you turn, not press??? :unsure: :unsure: I am confused...
dfitz
The button you push that switches drive modes from Normal, Eco, Slippery, etc.
BOB225DUSTER
Robert
2024 xlt atlas blue
dfitz
Very interesting that the HVAC module has anything to do with the drive mode selector. I did swap my HVAC module for one with the digital readouts over a month ago and thought everything was working fine.
I hadn't tried to change the drive modes until it rained and I wanted to see if I could tell a difference from Normal. Will have to see if swapping the modules back solves this.
someone posted a similar problem - and fix was a faulty A/C control panel module
not sure if related to your problem but could point Ford mechanic in the right direction
https://www.mavericktruckclub.com/forum/threads/drive-mode-selector-button-unresponsive.19171/
dfitz
Looks like reading through that other thread that they didn't find a way to change anything in FORScan. I will have to swap back to my original HVAC module if I want to change drive modes as the Bronco Sport module doesn't appear to support that.
SLingbarT
Saint John Indiana
2023 Hybrid Lariat Lux in Cactus Gray
It could be because the Bronco Sport uses an encoder dial to select drive modes.
I know I've seen ppl change the panel from an Escape, would that work better?
dfitz
I put an Escape on in and problem was solved
