Also, at 1500 miles, I performed my first oil change ( I know, for some of you it’s overkill, but to each his own). For the non FX4 version, it is super easy. There are 14 or so T27 Torx bolts holding a bottom tray in place that you need to remove to access the filter and oil pan. The plug is a 15mm. The filter is right there with easy access. I went with a Royal Purple oil filter (#10-2835). For oil, I’m using Amsoil 5w30 full synthetic.
