DIYs and HACKs for your Maverick
mave--rick
rick
goshen, ohio
1980 t-bird, 2003 ranger xlt, 2005 mustang,
Waterick
Laurens county SC
Mavster Mechanic
Hybrid
2022 XLT has built in dimmable ambient light in the front console / phone charge area. Ice blue only.
Mavster Mechanic
Hybrid
3D printed a custom ScanGauge III stand.
Ford Maverick DIYs and HACKs for your Maverick IMG_5348
Stand is held with double sided tape "command strip".
ScanGauge III is a friction fit.
Easy to move / remove.
Ford Maverick DIYs and HACKs for your Maverick IMG_5346
ScanGauge III is part of my 3.5k towing upgrades. I can watch temperatures of everything.
Ford Maverick DIYs and HACKs for your Maverick IMG_5855
gzebrick
Guy
Memphis, TN
25 Lariat AWD Hybrid 4K towing, '24 ioniq 6 limited AWD, '91 BRG Miata 5spd
My 25 Lariat has the ambient lighting - but it's half-assed from the factory. No excuse for removing the light you need most (the console / charger bin) and they cheaped out and don't provide any ambient lights in the rear. Maybe it's quarter-assed and they left out more than they put in!
The little USB LED light does seem to do the trick though.
BriBout
Jamestown, TN
2024 XLT AWD EB FX4 4K
How hard was it to run that cable up there?
Mavster Mechanic
Hybrid
Easy.
Had to drill a hole in the plastic coin tray or whatever you call it, but the hole is invisible from any seated position.
Pro Tip: get a short extension cable (ex 6") and leave it permanently attached to the scan gauge ($2).
Get a female / female coupler ($1) and leave it permanently attached to the $69 OBDII cable.
Then there is zero wear & tear on the expensive cord or expensive scan tool and you can remove it daily or whatever.
I usually put mine in the glove box when not being used to not tempt thieves.
BriBout
Jamestown, TN
Easy.
Awesome. I assume once the hole is drilled the cable can be fished towards the driver side and . I'll check it out. Thanks again for the pro tip on the cables too
DGMavLove
NY state
2012 Escape, 2026 Maverick ordered
