Delete
Status
Not open for further replies.
I was a 8cyl guy back in the day, I said I would never buy a 6cyl vehicle had 2 then I SAID I WOULD NEVER BUY A 4 CYL CAR had 2 of them, then I said I would never buy a 4 cyl car with a turbo they wont last I had 2, keeping in mind I only keep a vehicle the length of the warranty then I said I will never buy a hybrid, well do I have to finish the sentence, yes am buying a hybrid . but I can tell you for sure I will never buy a 3cyl unless its on a motorcycle or a go cart, I can promise you that.
Dang! Quit counting down just when I was looking forward to you finally going 0 cylinders!
Red Ryder
United States (TN)
22 Maverick XLT Iconic Silver
I'm not "freaked out", but I don't relish the thought of getting stranded or waiting for a tow vehicle. Part of my commute is in an area difficult for tow vehicles to access. I did add a Noco jump box and some Vice-Grip pliers to the vehicle in the hopes to mitigate the stranding issue, provided the failure mode is typical of others posted on the forum (that being that a jump box will allow me to limp to the dealer or home, and that the failed connection is the accessible one under the hood).
My guess is that the whole harness is suspect, otherwise the recall would likely just involve replacing the underhood lug.
Mr.Roboto.1975
Stoned Dude
Greater Cleveland area
06 Merc Mariner hybrid, 04 Silv 3500, 87 F-700
You either love hybrids and they're the greatest thing since sliced bread, or you don't. As an engineer, I consider them a painfully awkward, Rube Goldberg, "halfway to BEV" stopgap solution. The worst thing an engineer can do for reliability is make the whole system more complex. Guess what a hybrid does?
At the same time, I can emote and easily see how non-engineers would consider them a brilliant choice. When they work, they work great. When they don't work, they tend to not work very expensively. And in the Maverick, you've got a long warranty behind that hybrid. And it's dirt cheap, almost to the point where you figure there has to be minimal profit margin.
Lemme be fair and say buying an EcoBoost is just as problematic. A highly stressed, high compression, very hot engine with forced induction and direct injection is a perfect recipe for a short engine lifespan. It could be worse, you could be buying a Bronco Sport with a 3 cylinder turbo engine pushed way beyond sanity.
We're all on a journey to pure BEV anyway. A good number of members here will stomp and howl and scream "You'll pry my gasoline engine from my cold dead hands!". But if they live to buy a new car in 2030, odds are it will be a BEV and they'll love it.
Bottom line. If the hybrid is already worrying you, you probably shouldn't get one. If you're not a worrier and you like the fuel economy - by all means join a gazillion happy hybrid owners out there and put the money you save to buying your spouse a nice dinner out now and then.
To me, a vehicle that you have to find somewhere to charge with high amperage electricity is way more complex than a gas vehicle with electric motor assist and regenerative braking. I'm not an engineer, but I always wanted to drive a train. (I also have worked with engineers, and had to explain to them how things worked in 3D).
Mr.Roboto.1975
Stoned Dude
IAgree with much of what you said... I do find error with the statement below.
Hybrid drivetrains are electronically more complex, but mechanically far simpler. Pick your poison, I guess.
I recently picked up an 05 Mercury mariner Hybrid. The way the transmission is set up, I don't know why they don't build all cars like this, with a smaller motor to "shift" the transmission and start the engine. Once volume was high enough, I have to think the per unit cost would be below what current multi speed transmissions are. And no hearing the starter grind at intersections every time the stop / start activates.
Ken_Ohki
Ken
Charlotte, NC
BMW
When my Mav comes in I’ll have a 9 hour drive home with it. I was a bit worried about the cable issue but since my build date is in Sept I’m hoping it will be fixed from the factory.
PriusHater
Michael
www.rocketstem.org
The Maverick is my second hybrid vehicle., after owning a 13-year-old Prius that still has its original hybrid battery. Five months and just under 7000 miles on the Maverick and have had ZERO battery issues. So, I’m not worried at all.
Sliphorn
Missouri
2022 Ford Maverick XLT Hybrid
Please explain the recall. I am not aware of a recall concerning this issue.
Eagle11
Valley of the Sun
Another post shows how the internet isn't used correctly....
Gullzway
OK
1968 Ford Mustang Fastback
it’s just a simple take the non connected piece out and replace it with an eyelet and crimp it on. Replace the heat shrink as well. It takes less than 5 minutes!
Does it require a Copper or Aluminum connector?
013SamIAm
Samuel
Summerville,SC
2015 Flex, 1965 Ford Galaxie, 2014 Toyota Camry
We did copper at our dealership. Had a good crimp on it and done! No problems. Again about 5 minutes!
Sardone
Frank
Ford Explorer
I keep seeing more and more threads, both here and on Reddit, about Hybrid owners with battery drainage issues (I.e. waking up to a completely dead truck in the garage that needs to be jumped) or even hybrids that entirely shut down while in motion - including at highway speeds. This all apparently has to do with an issue with the wiring harness but I have to say, it’s making me second guess my thoughts about ordering a 2023 Hybrid. Anyone else starting to get cold feet?
No.
inthecabin
Andy
2021 Ranger Lariat FX4
Assuming it’s 4/0 lug. You can get a crimp tool, tinned lugs and heat shrink tubing for about $85.00 to DIY.
Status
