- First Name
- Keven
- Aug 4, 2021
- Huntsville, Alabama
- Maverick, '71 GMC
- Engine
- 2.0L EcoBoost
3FT-T-W8E-3-3-N-R-A19131so I got a Vin from dealer after locking my order for the 1.9% finance expiring on 10/4 .
question if anyone knows, are my assumptions correct below where I commented and can anyone help with the missing values I don't know. Thanks
Starting at the left side it reads
3FT made in Mexico
T restraint system in truck
W8E Front wheel drive (Hybrid I assume)
33 ?? this I need help with....???
N year 2022
R Hermosillo plant
A groups of builds A..B..C... etc
19131 Build number within the A group
3FT- Ford Mexico - World manufacturer identifier
T-Restraint system - brake system, gross vehicle weight rating, restraint devices and their locations.
W8E-Maverick Front wheel Drive - Make, Vehicle line, series, body type
or
W8F Maverick All wheel drive - Make, Vehicle line, series, body type
3- engine type, Hybrid 2.5 - Engine or motor type
or
9- engine type, Eco 2.0 - - Engine or motor type
3 - Check Digit - Used to detect fraudulent VINs.
Note: The check digit, found in position 9 of the VIN and compulsory for vehicles in North America, is used to validate a VIN. This is helpful for computers to immediately tell if there is an error or issue with the VIN. The check digit is calculated by removing all of the letters and substituting them with their appropriate number counterparts. You then take those numbers and multiply them against a weight factor table. You then have 16 numbers which you add together and divide by 11. The remainder is the check digit. If the remainder is 10, then the check digit is “X."
N-year code for 2022 - Model year
R Hermosillo Plant - Assembly Plant
A00000-Z99999- Sequential Vehicle Identifiers - Production sequence number.
