Dash Cam Power - FitDVR Power Adapter
Dave O
New Smyrna Beach Florida
Just trying to plan ahead and also avoid routing power wire down “A” pillar to fuse box or route power cord to 12 volt cigarette lighter plug anyone have experience or know if this is even possible in my 2025 Lariat AWD Hybrid - any comments or suggestions welcome
Johnkn
MD
Dave O
Dave O
Dave O
Dave O
Just completed the WolfBox G900 Tripro Dash Cam (3) Channels the last piece of the installation was grabbing power from the OBD II Port using the (2) pin adapter from WolfBox I couldn’t be happier with the install and functionality…
Ford Maverick Dash Cam Power - FitDVR Power Adapter IMG_6453
Ford Maverick Dash Cam Power - FitDVR Power Adapter IMG_6451
Ford Maverick Dash Cam Power - FitDVR Power Adapter IMG_6452
Dave O
Dave O
Huh? I thought you didn't want to run a wire up the A-pillar?
HRG
Well that was my original thought but after I started the installation I found out it wasn’t as intimidating as I thought. The Dash Cam install came out really nice no exposed wires, the power wire from the OBD II Port and the rear camera wiring across the headliner down the A Pillar (behind the air bag) dropped the power wire immediately into the dash cavity then routed the rear camera wiring behind the trim all the way down on the driver’s side - I ran the GPS wiring on the passenger side across the headliner down the A Pillar behind the air bag and tucked it in the corner on the dash
