Clear Side Marker Lens and LASFIT Side Marker LED Bulb installed!
CaReviews
Atlanta, GA
2023 Ford Maverick XL 2.0T, 2007 Ford F-150 XLT,3
Installed clear side marker lens and @LASFIT Side Market LED Bulbs on my Maverick! The bulbs are super bright (almost like fog lights bright) and the lens are of a decent quality for being an eBay part. Here's how she sits currently!
Ford Maverick Clear Side Marker Lens and LASFIT Side Marker LED Bulb installed! IMG_6632
Ford Maverick Clear Side Marker Lens and LASFIT Side Marker LED Bulb installed! IMG_6376
rk06382
Robert
Alaska
2025 Velocity Blue Maverick Lariat Hybrid, 1990 Ford Ranger XLT SuperCab
urwatuis
Melyssa
Vermont
2023 Maverick XL
Installed clear side marker lens and LASFIT Side Market LED Bulbs on my Maverick! The bulbs are super bright (almost like fog lights bright) and the lens are of a decent quality for being an eBay part. Here's how she sits currently!
I love it.👍
Maybe the brightness will keep other drivers from deciding to set up camp/pacing next to you while driving down the freeway at night.
I wonder if they have Amber ones that are just as bright. In Nevada we have to have Amber.
Voodude
Voodude
Cali
Ford Maverick XLT FX4 Lux
I was installing a set. Started to see the fender crease using a plastic pry tool. Didnt continue with it. Any special things used or added to prevent a dent?
kmish203
Jeep Renegade
I wrapped the pry tool tip in painters tape and also kind of pushed the tool and pulled away from the tire instead of using the bend in the pry tool as leverage. They're a little finicky but I've been able to get them out with no damage
MaVick
Brevard, NC
24 Maverick Lariat, 24 BMW i5 M60
Amber lights are available, installed them on my Azure gray truck.
24atlasmaverick
Christopher
Buffalo, NY
2024 maverick XLT, Lux, FX4, AWD, 4K
There’s a clip on the back that you need to release. Just pull wheel well liner back and reach in!
Wilklersticks
Bryan
WI
25 Lariat Hybrid 🚀⬜
Correct me if I'm wrong, but isn't the amber color required by law? e.g. the lens can be clear, but when it's on it needs to be an amber LED? That's what I did.
Ford Maverick Clear Side Marker Lens and LASFIT Side Marker LED Bulb installed! image_2025-06-05_090738036
Wilklersticks
Bryan
WI
25 Lariat Hybrid 🚀⬜
If you can, you definitely want to come at it from the inside. I had to use a long metal rod to get around a metal mount on the driver's side, but it's easy enough to push in the retaining click and avoid the risk of dinging the paint or deforming the body.
Voodude
Voodude
Cali
Thanks great idea will try that
rk06382
Robert
Alaska
MaVick
Brevard, NC
It is easier removing from the fender well vs. the video. You can push it out easier without damage to the fender exterior, especially on the passenger side w/o the bracket in the way like driver’s side. It’s all a matter of preference.
Wilklersticks
Bryan
WI
25 Lariat Hybrid 🚀⬜
