What do you mean by bed spacer? The holes in the drop in liner are not big enough to fit the flange for the tie down. The bed liner has to be cut to get the flange to sit flat. Am I missing something?
The bedliner came with spacer pieces to use with the factory tie-downs (if you had them) so they would not crush the plastic when you installed them and bolted them tight. With the cup plates set down in cut holes, not a necessity.What do you mean by bed spacer? The holes in the drop in liner are not big enough to fit the flange for the tie down. The bed liner has to be cut to get the flange to sit flat. Am I missing something?
