Camping with rooftop tent and 12 ft kayaks
BlueOval1954
Looks like you got yourself a nice setup. How easy it it to deploy the tent ?
bingledorf
Rick
Bend, OR
2025 XL Hybrid AWD 4k tow
Very very fast to set up.
Unclip the corners an it pops up.
Insert the struts to hold the awnings and done.
Take down takes some finesse because it wants to pop back up as you stuff it all in. A little practice and technique makes it fine.
Very comfortable, roomy. Nice space.
scott1070
Scott
calgary
25 lariat
Why is the tent mounted with so much overhang in the rear?
bingledorf
Rick
Bend, OR
By shifting it to the back, it can be lower, just clearing the roof and creating a more efficient airflow. When I had it higher and more forward I noticed a hit on mileage. With it low, no so.
Ford Maverick Camping with rooftop tent and 12 ft kayaks 1000003248
bingledorf
Rick
Bend, OR
I might try drilling a new position in the elevate rack to raise it just enough to clear the mini antenna and mount it more forward and test mpg again.
BlueOval1954
Don't hit that mini attenna. Mine got damaged somehow and the dealer said it will be $1,300 to repair. I questioned the cost and they said labor to remove the headliner etc. It still works so they can pound sand.
Realtruck
Diamond Sponsor
Realtruck
Ocala FL
I'd recommend just getting an antenna cap so that the tent can clear without adding height to the rack.
Modifying the rack is possible, but that will kill warranty, and you have to get it exactly right or it's going to be off. It's also work that is probably unnecessary.
I have the Elevate on my Maverick, with a rooftop tent, and I have a 3/4 antenna cap that replaces my antenna. The tent clears the shark fin by a little more than 1/2 inch.
Also, keep in mind, the higher you have that tent, the more it will disrupt air flow, and your more likely to scrape low hanging branches.
Hope that's helpful! :)
-Todd
bingledorf
Rick
Bend, OR
Thanks Todd.
I didn't know about antenna caps, good solution, Ill try it.
Like this?
Ford Maverick Camping with rooftop tent and 12 ft kayaks 1784306019836-rm
ToddsTruckLife
2022 Maverick XLT FX4 LUX 4K 360 VB
Thanks Todd.
Like this?
I got it off Amazon. It came as a kit with a 1.5" antenna and a 3/4" antenna cap. Realistically, you could probably just unscrew the antenna you have and no one would even see it, but you'd know it was there. That would bother me, personally. 😆
Ford Maverick Camping with rooftop tent and 12 ft kayaks 20260717_114906
scott1070
Scott
calgary
25 lariat
My rtt is about the same height from the shark fin as yours is. I keep the antenna on, it just bends it down in an arc. I tried replacing it with a shorter one but the reception was terrible
ToddsTruckLife
Yeah, I'm sure my reception is diminished, but I get all my music through phone interface and never use the radio.
-Todd
bingledorf
Rick
Bend, OR
Spotify!
