Cabin Light not working at night
haze10
Rhode Island
2024 Maverick Lariat Hybrid
So my interior cabin light comes on fine during the day, every time I open the door. But for some reason it doesn't come on at night. Definitely not in deep sleep mode as driving the truck daily. Any ideas.
haze10
Rhode Island
Yes. But never drained the battery and truck is only 18 months old with 10K miles. If the battery, why work during the day and not at night?
haze10
Rhode Island
so far yes, it never seems to come on at night but does during daylight.
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
Your OEM battery is sulphated and about to die completely. I'll bet it measures below 12.0V after an overnight sleep. Have you had all your recalls and SSM53801 for the a/c power leak fixed?
A while back I noticed this.
At night if I come home and I'd manually turn off my headlights. In the morning when I get in my Maverick before I put the key in the ignition the interior lights will not come on.
Once I start the truck the headlights revert to the AUTO Default and the interior lights will come on when the door is opened.
Chopperbobc
WI
2023 maverick xl
There is something else that controls the cabin lights, but I don't know what it is.....after a few days of not running my cabin lights fail even though my 12 volt AGM battery is at 12.6 volts..... can someone explain why this happens....ty Bob
Master Blaster
Master
Toronto
The only other thing that controls the cabin lights is the 3-position switch in the centre of the roof console. It is normally in the centre position.
Chopperbobc
WI
2023 maverick xl
Mine is always in the middle position and this happens many times....
MaverickMark
2023 Maverick Lariat
I got the sleep mode notice everyday and I drove the truck everyday. I think it's your battery too.
Master Blaster
Master
Toronto
Your battery is totally toast. I think that at night with the extra headlight and taillight loads, the voltage is decreasing from your dead battery to the point where the system is going into self-preservation sleep and not turning on the nonessential interior light. During the day you are just above that trigger level and the light will go on for a short period.
boxster03
michael
santa fe NM
2023 Maverick XL Area 51
it makes no difference that your truck is new or you drive it daily - deep sleep mode is an issue with bad software engineering causing a constant drain on the battery and the battery not fully charging when you do drive it - you can change the battery that may or may not "fix" the issue
