Cabin fan has a mind of its own.
hshagan
Howard
pa, usa
2024 ford maverick
I have noticed with increased frequency that will increase speed for a few minutes. When this happens none of the environment controls work till it resets.
Eggflipper
Gene
Massachusetts
2024 XLT TERRAIN
Yes, the fan speed appears to have a mind of its own. The computer controls it, and it does seem to do what it deems appropriate. I’ve accepted it.
It is adjusting temperature and/or humidity levels to reduce the possibility of condensate forming. The AC may be running defrost cycle.
Johnny maverick
Nh
22 mav 16 superduty 89 xr7 sc 5spd 84 gt turbo
It will also adjust for calls. Then go back to original setting after the call ends.
zach57x
FL
2022 Maverick XLT
Wow this makes sense. Was on the phone during a long drive and then shortly after the call ended it sped up without me touching the speed dial
olderthanyourdirt
so Cal
2025 Maverick
If you have a Lariat the climate control will override your fan setting until it reaches your temp setting
Geppetto
Holly Springs GA
2024 Maverick Lariat
And the AC compressor will run without AC light being on!
