Buy OEM bed tie down system
gte105u
Katy, TX
Put my '23 order in. Didn't get the bed liner and bed tie down system. Was hoping to avoid the liner constraint. And didn't want the rails in place before I do an aftermarket bed liner.
I know there is a video for a DIY rail system which looks decent. Also a number of aftermarket systems. But the cleat handles of the OEM are pretty slick. Did some looking for them couldn't find them. Anyone see where to buy them, or something similar (as in the ease of moving the cleat around)?
gbdoom
Indiana
2020 Subaru Outback Limited XT
Not sure about the rail system, but my dealer said most of the options I wanted (hitch and floor mats) could be ordered from the parts department at the dealer or online, and they recommended to do it just to limit constraints. You should be able to get that installed or at least ordered at the dealer after your bed liner.
gte105u
gte105u
Katy, TX
Good thought. I had thought similar. Didn't see on Ford's accessories page. I was hoping to avoid the dealer and order online since the install should be pretty easy.
Good news, there are many months until it comes in for me to figure it out...
gbdoom
Indiana
Getting it in the driveway will help! I couldn’t find a part number either and it looks like nobody else can online. Maybe call the parts department and see if they can find it on their end?
kpomeraning
Keith
Akron, OH
'22 Mav on order, '17 Focus, '16 Focus, '09 Fusion
Order the hitch or you'll find you won't get the trailer wiring... A few forum members had that issue with their '22 models and it was apparently a big PITA.
gte105u
gte105u
Katy, TX
I'd get a factory hitch when possible. They always look better and the wiring is cleaner as mentioned. I got 4k so it's moot for me.
MAVRICK
Any
2023 XLT
RE: Bed Tie Down Rails with Cleats
Locate a wrecked Nissan Frontier at a Junk Yard, remove bed tie down rails with factory cleats, if needed, cut rail length to Maverick size, install in Maverick.
Other truck models may also fit ... I can only validate the Frontier.
gte105u
gte105u
Katy, TX
Interesting. How hard are they to get off? Use any funky screws or pop rivets or anything crazy?
MAVRICK
Any
2023 XLT
Easy. No special tools. Some Torx Screws. The cleats slide right off. Make sure you save all the washers. If wanted, you may spray coat the rails for either rust proofing and/or color matching.
On the new install, use plastic washers between the rails and the truck bed and use some vaseline or Lithium grease on the screws. This helps prevent corrosion and or reactions berween two potentially dissimilar metals.
LeersMav
Maximus GP
Orange County, CA
Based on this thread:
Just an FYI from a current owner, order what you want from Ford having add-ons as part of the monroney sticker.
The retail price is higher on the Ford accessories.com website then if you ordered it through the ordering system. A few items are the same price, but MOST are higher on the accessories.com website. (Just stating my experience.)
gte105u
gte105u
Katy, TX
Concern with this is if there is a run on parts for an accessory they could hold the whole vehicle up over it. If I can easily get it done after receiving (see bed liner) or install myself (see rails, tonneau) I'd rather not risk putting the order on hold for $50
LeersMav
Maximus GP
Orange County, CA
Sounds reasonable.
Just wanted to mention it so there are no regrets later on. Some owners, and potential owners, have regrets not ordering or waiting for some options.
For me, time was not a concern. Did not matter how long I had to wait. I ordered the Lariat First Edition Rapid Red ..... it was considered LA (Late Arrival) because it was ordered fully loaded and Rapid Red Tricoat Metallic paint.
paneubert
Seattle
2023 XL/4K/AWD/CoPilot/CactusG/SlidingRearWindow
Don't know if these are the style cleats you are talking about. Check them out.
They go well with these screws....
austinzone
Tampa
Honda Element
OEM rail system: NZ6Z-9955200-A Rail Assembly Pick Up Box $320.60
Got it from fairwayparts - used my FordPass points towards it.
gte105u
gte105u
Katy, TX
Came with cleats and rails? Pricey vs unistrut hack but it's clean
