BOOST LEAK 2024
Mudduck
JD
Utah
24 Maverick FX4. '26 Toyota Sequoia TRD Pro. 72 VW Ghia
I have been hearing what I describe as an Aztec Death Whistle noise under 3/4+ throttle. I purchased a cheap smoke machine on Amazon for $65 bucks. Found the leak, at the FMIC where the charge pipe connects. Tightening clamp did not help, and upon removing the hose and blocking it off, there is a crack where the neck meets the housing.
Took it to Ford dealer, and they smoked it and cannot find the leak…. 🤣. Wanted to charge me $175 diagnostic fee and send me down the road. I went out to where my truck was parked and hooked up my machine, smoking in the same spot! Got the service manager out to verify and told him I refuse to pay the diagnostic fee. I was polite enough to him, but expressed that he should source qualified techs. Asked him how much his smoke machine cost (north of $1000). I’m way too impressed at this point. Cancelled my extended warranty as well.
I will be ordering the CVF unit today.
almost unbelievable.
https://a.co/d/083mFnNj If anyone needs one that works well. No compressor needed.
Ford Maverick BOOST LEAK 2024 IMG_3251
Ford Maverick BOOST LEAK 2024 IMG_3250
Triangle6887
Eastern Oregon
'24 Ford Ranger XLT FX4
How many miles? Is it still covered by warranty or are you having to pay out of pocket?
Mudduck
Mudduck
JD
Utah
I have 18709 miles. It is under warranty still, but based on this experience Id rather just swap for the CVF and DIY.
I already started doing my own oil changes because the last 3 dealers I have been to always leave the skid plate bolts loose, and twice i have been missing the smaller bolts up front.
FX4 skid plate weight 27lbs.... If that were to come off at highway speed, I cant imagine the damage to my truck or the unlucky person behind me. A dealer would never own that, I would get all the blame.
Johnkn
MD
OP, are you anywhere close to Centerville, UT?
Mudduck
Mudduck
JD
Utah
Johnkn
MD
About an hour drive, per google maps
Then, You’re an hour away from one of the best shops in the country, not that it helps with warranty repairs.
good luck
Nw_adventure
Salt Lake city
good luck
Which place in Centerville ? I did have my BOV/Wastegate go south that was not able to hold proper peak boost- Got it swapped under warranty -
Do any of the CVF units hold more boost and if so does the OEM/ECU then override that ?
Johnkn
MD
Mudduck
Mudduck
JD
Utah
Nw_adventure
Salt Lake city
Any performance upgrade with the CVF unit ?
Mudduck
Mudduck
JD
Utah
The stock intercooler heat soaks quickly and degrades performance. The CV Fab intercooler is like 240% larger and keeps temps down.
Nw_adventure
Salt Lake city
I was talking about the BOV -
Mudduck
Mudduck
JD
Utah
Oh, ok... The CVF is the intercooler and down pipe that I got. My BOV is Kompact Dual port. It wont add HP, but it will help protect your turbo, makes a whoosh sound. Thats about it.
Cancunbadlands
Cancun
Cancun
I'm interested in the BOV
