ladyhawkgt
J
2003 Mustang GT
Oh, of course, after I already purchased with bottom only. Does anyone know how I can get just the side covers without needing to order the bottom.
you might try Bedrug themselves, but i believe they zip together, so if you don’t have zips i’m not sure?
Dad
Thanks, I'll look around. Not a "must have" at this time, but had I initially known about the sides, I believe I would have included them.
ladyhawkgt
J
2003 Mustang GT
initially, they did not have the whole cover, but Ford does not sell it anyway as far as i know.
Dad
You are correct. I purchased from Ford (Points) and there was no option for the side coverings. Thanks for the info.
Ricstar
Jeep CJ7
No need and would never use, but DAMN THAT IS GREAT!!!!!
AllBlkMav
Las Vegas
The bed is done. I added some Pyle marine Bluetooth speakers. LED strips, switches and USB ports from Amazon. The speakers run independently of the truck's sound system - so mostly for when I'm working outside or hanging out. They're waterproof and made for marine applications, and sound decent for a bluetooth speaker system. The power is switched there, the factory bed power supply runs for about an hour and a half after you shut the truck off, and the usb port has a volt meter so I can keep an eye on the battery level. These are 6" speakers, and are just a little big, necessitating cutting the switches and ports back just a bit to fit. If I could have found 4 1/2" speakers, that would have been better, and would have allowed use of a couple of cubbies
Dope install
