Blacked out Headlights/Brakelights Modification on 22 Mavericks?
luciusxlt
Alexis
miami
2022 for maverick XLT
Ok thank you! Did you use the zep that said 25% stronger on the bottle?
i could not find it. I use this one it work perfectly i got it from advance auto part, this method is only for the taillight, not headlight for the headlight you need to crack open the headlight so you don't take the chrome of the high and low beam reflector
Ford Maverick Blacked out Headlights/Brakelights Modification on 22 Mavericks? 1674668727509
MikeyG
phila
Ok.. yes I saw someone mention that it’s only for the taillights. So I basically takes all the chrome off so there won’t be anything to reflect the light inside? So that’s why you said to upgrade to leds builds? Are the BAP done the same way or they have some of the chrome inside?
luciusxlt
Alexis
miami
i dont know on the original BAP i would assume it has some chrome on the reflectors , but with the lasfit Led its so bright you dont need it
JamesC
LI, NY
06 Mustang GT
Has anybody else had quick success with the regular strength Zep? I plan on doing my tail lights soon.
FunctionSpec
San Gabriel Valley, CA
2022 Maverick HYBRID XLT LuxPkg
Did mine today using the Zep Industrial Purple Degreaser found at Home Depot in the yellow bottle container. Used full strength and it stripped the chrome off in 10-15 minutes. Didn't have any issues and used just 1 gallon for both taillights. Could have probably used just half a gallon if I reused the degreaser. Seems to be just as strong as whatever old formula they had before. The chrome came off super easy and clean. This was bought in Southern California so don't know if it's regional. Rinsed using reverse osmosis filtered water for a spot-free finish.
CG_HotWheel
Justin
Tyler Texas
2022 Maverick XLT
Thank y’all so much for introducing me to this easy (and cheap) tail light hack that saved me from spending waaaay too much money ordering and possibly never even receiving the Black Appearance package tail lights. This weekend, I did my tail lights and third brake light up top and it turned out so much better than I could have even imagined! So thanks again for sharing this!
Ford Maverick Blacked out Headlights/Brakelights Modification on 22 Mavericks? A1D4A184-695E-4009-9C55-A5B2B60E9261
Ford Maverick Blacked out Headlights/Brakelights Modification on 22 Mavericks? ECE92B97-1415-4F92-A688-84425A9A92DB
TRUCKHEF
SOCAL
22' Ford Maverick XLT
How bright are the rear brake lights after stripping off all the reflective surfaces...wouldn't this be a safety issue?
mdl20813
Idaho
Cactus Gray Maverick XLT
it only strips where the reverse lights are in the middle of the housing. There’s no issues, especially if you have swapped to LED bulbs
TRUCKHEF
SOCAL
You sure? just checked the taillights, its all connected and hollow. There's no barrier to prevent the degreaser from stripping the brake lights as well. Love the mod looks so good, just not sure if its worth getting rear ended. Have you seen how many threads there are with Mavericks getting rear ended and totalled recently?
mdl20813
Idaho
Could there be some chrome in the brake lens portion I didn’t bother looking at when I did it, sure. Would it be enough to all of a sudden dim the lights coming through an already red plastic lens, no.
I did this months ago and there is 0 difference in the brightness of any of the taillight sections. I can’t speak for anybody who still runs the halogen bulbs but brightness is a non issue if you have LED bulbs in. Even had my wife trail me before and after and she said they looked the exact same.
1ma2t
UT
I am interested in this mod. But curious if it will work on lariat tail lights.
I know lariat has strip of led around the edges and don’t want to ruin the lights.
Lane
Lane
Central Wisconsin
photos.app.goo.gl
I stripped my tail lights and rather than wondering or speculating on the difference, I took a few photos so I could see. Keep in mind, these were taken in daylight.
This photo shows the stripped lens on the driver's side, stock on passenger side. These are the factory halogen bulbs. The lights are on so this is the tail light only (no brake):
Ford Maverick Blacked out Headlights/Brakelights Modification on 22 Mavericks? stock bulbs, stripped left, headlights on
Again, this was tail lights only that we're looking at in the daylight. Brake being applied was even brighter. Even with this difference, nobody is going to tell you 'hey, your tail lights are dim' when they look at them at night. They're not dim, they're just not as bright.
As a part of this project, I did put Lasfit bulbs in the rear. The Lasfit in the stripped light housing did bring back any lost brightness compared to the original halogen bulb in the original housing. If you're that safety-conscious, it's definitely worth doing.
If Mavericks are getting rear-ended, it probably won't be due to that small amount of light difference. It'll be from someone texting, talking on their phone, not paying attention, or they're just plain crappy drivers. A light that's a little brighter won't fix that.
KenJ45
2022 Ford Maverick XLT 2.0L Ecoboost
Do they offer the black trim option on XLT models? If so, maybe I can just buy them from the dealership and then sell my stock headlights to make back some of the money. I'm feeling too lazy to do all of this work but want the look, lol.
