Been sitting since Christmas
commadorebob
A lot of opinions so here's mine:
Jump it off and let it run for about ten minutes before going anywhere.
NedF
BC Canada
Was a '23 now a '24 Lariat Lux
So is it bad to just take off a battery cable. My Camry manual says to disable battery if not using it for two weeks which I do if I am parked at an airport for very long......
Hopefully all of the settings are stored in non-volatile memory of some sort and the truck can wake up in the same state it was in when you disconnected the battery, but I would not want to let mine sit longer than a few hours disconnected for fear I might brick the truck!
ZABSMAV
Utah
2023 Maverick Lariat Hybrid
That would defeat the purpose of the FordPass app telling you where your vehicle is and if you had it stolen while you're away you could not know where your vehicle was when it went back into deep sleep. Ford engineers just need to get off their rumps and get this problem fixed. It's gone on way too long.
RR - All the way
GA
Wow, if my Mav is stolen I am not sure the location of where it went to sleep is real meaningful. I would suspect most thieves can disable this anyway. However, I agree that Ford needs to get the problem fixed.
Hockeyfish11
Ed
2024 Maverick
My Maverick has been sitting since Christmas in my garage (I’ve been in Florida). Two concerns with startup 1. 12v battery - assuming it will be a simple charge, and 2. Upper engine lubrication during start up. Assuming dip stick is at the halfway mark I was thinking of adding oil to the full mark and hoping it drips down and provides some upper engine lubrication. Your thoughts
Hockeyfish11
Ed
2024 Maverick
Well, I’m back. Would nor start, turnover, activate. Charged 12v battery at battery. 40 minute charge to 100%. Charge lasted seconds. Charged again using terminals under hood. Took 8 hours to get “System” to 100%. Ran like new
SafetyGuy
Andy
Manitoba
Yep, "batteries is batteries" and a trickle charger in your extended absence should do the trick (in the truck if possible).
Might be a good idea to treat/stabilize your fuel while you are gone, as it can go bad.
Run it to get treated fuel throughout the fuel system. Helps prevent varnish etc forming and plugging things up.
I did both when deploying. Just pulled the batteries and had them inside on a trickle charger. Not a Mav of course, an old F150 so completely different beast.
At any rate, great news!
Andy
