- First Name
- name
- Jan 13, 2022
- hinterlands
- 2022 Ford Maverick XL, AWD, 4K tow, 2.0L EcoBoost
- Engine
- 2.0L EcoBoost
So you are saying Ford techs now are also certified welders? You still didn't answer the important question if you plug in your harness does the IPC know a trailer is connected? The oem 4 pin will give a message in the cluster when it does. If doesn't it is simply tapped in and not fully wired to oem spec.Again, false information on the OEM hitch receiver. I went through all that with the ordering of the original OEM hitch receiver and 4-pin wiring harness.
The hitch receiver is welded on the crash bar just as it is at the factory. It IS NOT bolted on. IT IS welded onto the crash bar. IT IS the same bar, hitch receiver as used at the factory. I tell facts, not opinions of what you think it is. And NO, the wiring is NOT tapped in. I’d highly recommend you go research before stating opinions. This process has been discussed in great detail here. And all is based on research and facts from those of us that actually own Mavericks.
