- Jul 30, 2024
- New Jersey
- Ford Maverick
- Engine
- 2.0L EcoBoost
Maverick crew, this one’s for you! 🛻
If you’re still chasing stuff around the bed, the High Version Bed Divider with Molle Panel is the fix you need — and it’s now taller for even more control.
Compatible: 2022 / 2023 / 2024 / 2025 / 2026 Ford Maverick
What Makes It “High Version”
Total height is about 11.6 inches — that’s roughly 3.9 inches taller than the standard version. This extra height seriously boosts vertical storage ability, stops tall or oversized items from tipping over, and gives your bigger cargo real protection.
Function
The cargo divider is foldable and features an integrated tension-adjustment mechanism that removes slack and locks your gear securely in place. You can separate common items like fuel cans, keep the truck bed organized, and grab what you need fast — no more digging through a mess.
Material
Made from high-quality aluminum alloy — lightweight yet tough, and corrosion-resistant. Strong enough for heavy-duty cargo, but still easy to handle and store when not in use.
Installation
No tools, no drilling. Simply unfold, position it in the bed, and dial in the tension mechanism until it’s rock solid. Seconds later, your cargo is locked down and your bed is finally organized.
Real truck photos & full install video are attached — check them out below!
20% OFF — EXCLUSIVE DEAL
Original Price: $179.99
**Now: $143.99** with code
Link: https://www.amazon.com/promocode/A3HGCWFRYOVKZK
Code: KWKAI6IW
Expires: 8/2 at 11:59 PM — don’t sleep on this one!
WANT ACCESS TO MORE MAVERICK-ONLY DISCOUNTS?
We’ve got a private Maxzina Maverick Accessories where we share exclusive codes, real install photos, and legit owner mods. No spam, just solid Maverick talk.
Drop a comment or hit the join link — let’s build the best MTC crew together!
