Bed auxiliary 12 volt fuse #84 question
Warren
Roseville , Ca.
Morning , I installed a 12 volt power socket above the passenger side cubby and wired it directly to the provided harness
which is plugged in , and ignition on with engine running.
It does not power up , I am trying to find out if fuse 84 is in fact installed , without taking the fuse box apart.
Does anybody who has already done this know if the fuse was in fact in place on their truck ?
Thanks
Ford Maverick Bed auxiliary 12 volt fuse #84 question FDE608F6-CC07-4851-8D78-3FA9E02CB1B2
Ford Maverick Bed auxiliary 12 volt fuse #84 question 2DD1BC67-6D39-4178-942D-C0A0D4933243
Ford Maverick Bed auxiliary 12 volt fuse #84 question 659D38FC-1B78-4D13-A994-71456BF44B75
wax87
Stuart
Dallas South
2004 Avalon
Ford Maverick Bed auxiliary 12 volt fuse #84 question 1691508126457
So does this mean the inverter actually has 720 Watts? (12V * 60A = 720 Watts)
It's rated 400W 110AC continuous but one also has to account for extra 12V current due to conversion losses and allowance for surge draw. Plus power used internally for the module itself and small things like the LED indicators.
wax87
Stuart
Dallas South
2004 Avalon
I know what is stamped on the door, I just wonder what the real output is. How much 'safety margin' are they putting into it? Maybe inverters are fairly inefficient?
80-90% efficiency. So on the pessimistic end that 720W is now down to 576W.
Sembazuru
Wilmington, de
2023 Maverick XLT Lux Hybrid
In addition, I think the inverter has in internal cutout. I forget the video, but I remember seeing someone testing different loads on the inverter in a YouTube video. When he overloaded the outlet, not only did the output of the outlet cut out, but I think the indicator light started blinking. That sniffs to me like the inverter has internal safety limits and limit trip indication. The higher rated fuse is probably to take care of efficiency overhead, and to protect the truck from the inverter faulting to short internally.
wax87
Stuart
Dallas South
2004 Avalon
where is this indicator light on the Mav?
wax87
Stuart
Dallas South
2004 Avalon
do you also get a warning on the dash somewhere?
BlueSpec1
Gene
Read in the service manual:
The DC/AC inverter converts 12 volts DC to 110 to 230V volts (Depending on market requirement) AC
to power AC devices rated 400 watts or less with the vehicle in park, or 300 watts or less with the
vehicle in drive.
