Bed and Console plugs not working
  • Thread starter Deleted member 42654
  • Start date
  • Watchers 4
Guest
My plugs for the inverter, both bed and on the back seat console are not receiving voltage. Lights are not on and nothing plugged in works. Number 84 main fuse seems good and number 6 in interior fuse box seems good. Ohm test shows conductivity. What’s next the inverter? If so where is it and how would I get it out to check or replace it. Thx.
Dr.Me
Daven
2025 XLT FX4
Does your mav still initiate auto stop/start? May have low voltage battery. It saves enough juice to start the truck but it will turn off some features/accessories.
Carlitos_92
If you have not already, I’d do a forum search for “inverter” and so on. This is a monthly topic. Sometimes it is a loose connector under the bed, sometimes it is a warranty issue…
Guest
Unfortunately , out of warranty. Thx
mgr1001
Michael
24045 Woolsey Canyon Road
Had the same problem. Took it to the dealer, who couldn't find anything wrong. They did, however point out that there is only power to these sockets when the ignition is on (not sure if the car needs to be running). My truck now has power when ignition is on.
Toadhopper1
Palm Bay Florida
2024 Lariet Tremor
I took mine in to dealer last week for this and was a bad outlet in bed of truck covered under warranty
BlueSpec1
Gene
Guest
Thank you very much.
What does DTC, DMM, BOM stand for?Fuses number 84 and 85 under hood?
Where is the inverter and how do I access it.
BlueSpec1
Gene
DTC are the Diagnostic Trouble Code a code scanner displays when the car has a trouble.
DMM is a Digital Multimeter. They have diode check function. LEDs are diodes.
BCM is the Body Control Module that contains and controls numerous functions in the truck.
Inverter is under the floor console:
https://www.mavericktruckclub.com/forum/threads/how-to-prop-up-center-console.56957/post-963583
Ford Maverick Bed and Console plugs not working 1751211947765-5n
One fuse is under the hood a 60A, the other is 10A in the BCM, F6.
Under hood:
Ford Maverick Bed and Console plugs not working 1751210976571-x2
Ford Maverick Bed and Console plugs not working 1751211010369-5
BCM F6
Ford Maverick Bed and Console plugs not working 1751211157856-l2
Ford Maverick Bed and Console plugs not working 1751211195955-g5
My Maverick's 400W Inverter modified sine wave:
Ford Maverick Bed and Console plugs not working 1756827079058-as
Storm Ranger
Raleigh,NC
97 Explorer, 17 RAV 4, 22 Lariat Maverick Hybrid
My 22 hybrid the ignition has the be on for my inverter to put out power to the power plugs.
