Bed 12v oulets
Nighowl2000
Roy
Ottawa
2022 ford Maverick lariat
I added these 12v outlets today: https://a.co/d/9ZrRI98
I also have a 3 way switch so I can choose truck bed power or the hidden motor cycle battery in the cubby I have hidden.
Ford Maverick Bed 12v oulets IMG_20221218_144736
Ford Maverick Bed 12v oulets IMG_20221218_144731
CSmith
CJ
Southern Indiana
2022 Maverick XLT FX4, 2020 F150 XLT FX4
You have a 12-volt motorcycle battery tucked away in the other cubby? What is that used for? How do you keep it charged?
Nighowl2000
Nighowl2000
Roy
Ottawa
My led lighting in my bed... The truck 12v times out after 15 min (unless modified in forscan). How I keep it charged... Have a hidden connection for solar panel or clamps for battery charger.
Raymundo76
Ray
Mesa Az
21 Mazda CX-5
Nice job. If you connect a trickle charger to your 12v outlet, will it still time out after 15 min.?
respi133
TX
Maverick Maverick
Feel like running us through that set up and install? Would be interested in how/where you've rigged it
Nighowl2000
Nighowl2000
Roy
Ottawa
Yes. Unless you modify the time in forscan.
Nighowl2000
Nighowl2000
Roy
Ottawa
So battery is in cubby with negative and positive going to the left connections on the 3 way switch
On the right side the switch has the 12v power from the truck
The middle connections feed the accessories like my led bed lights and the power station (usb/Aux sig power).
I have another direct wire connector directly to the battery in the cubby for charging like solar or battery charger.
Ford Maverick Bed 12v oulets IMG_20221219_120052
Ford Maverick Bed 12v oulets IMG_20221219_120802
Ford Maverick Bed 12v oulets IMG_20221219_115921~2
Ford Maverick Bed 12v oulets IMG_20221219_120017
Nighowl2000
Nighowl2000
Roy
Ottawa
Thinking of getting this battery isolator so aux battery will charge off of truck power.
Dual Battery Isolator 12V 50Amp https://a.co/d/fCoscZG
mightymuskrat
Jordan
Hamilton, Ontario, Canada
2023 Cactus Grey XLT Hybrid
Will the bed 12v pigtails 'wake' when you hit lock/unlock? I know it times out after 15min, I'm planning to install some bed lighting, and would like to be able to turn the lights on when coming back to the truck. I can find lots of posts complaining about it timing out, but not much info on whether there are any tricks to get them to work when returning the truck when it's off.
kjammer
Kenneth
Harrison Twp, Michigan
2021 Ford Explorer 2014 Ford Fusion SE Hybrid
Very neat. 👍
