Avs bugflector ll installed
bckrupps
Jeremiah
Fort Worth
2022 Ford Maverick XLT
Just fyi they sent me a warranty replacement as I had similar issues to what was posted here. They also informed me they identified the casting issue and have since updated it. The new one went on perfectly. Everything lined up and no warping like issues on the right side. The grommets are still the same but with it lining up straight and flush now they worked well.
OleKennyRoy
Kenny
Maverick Lariat
Thanks for the update. Just placed an order from RealTruck.
Gullzway
OK
1968 Ford Mustang Fastback
I love the original, now discontinued but can still be found, Aeroskin 2. It has the bump that actually deflects wind/debris over the truck. I put it on after a rock hit and cracked my windshield 12 days after I bought it. Now hardly anything hits the Windshield while driving. Also preferred the 3m stick on as it doesn't flap around like the one on my Sport Trac did, which actually ruined the paint underneath.
Ford Maverick Avs bugflector ll installed IMG_20220412_130217
bckrupps
Jeremiah
Fort Worth
Sounds good. That's where I bought the original and got the replacement from so hopefully you're good to go and get the revised version. I had to wait a couple weeks as they were backordered so I am just guessing they pulled the old stock. I had sent pictures to AVS also so it was essentially a 3 way conversation via email. Both AVS and realtruck customer service was excellent.
bckrupps
Jeremiah
Fort Worth
I like that design more but for no reason other than personal preference I wanted to avoid the tape and also I like that the AVS overlaps the fenders also.
All4spl
Longwood, FL
2023 Ford Maverick XLT
I too ordered one of these and had the same issue the inner two mounting flanges would not line up. The outter ones were fine, I contacted real truck and they simply RMA'd it and sent me a refund. Sad because I do NOT want a stick on one, and this was the only one I know of that uses this method to install.
OleKennyRoy
Kenny
Maverick Lariat
Well, looks like there may still be some ill-fitting ones in the wild...
Ford Maverick Avs bugflector ll installed 1675083791583
Ford Maverick Avs bugflector ll installed 1675083802393
Ford Maverick Avs bugflector ll installed 1675083815615
Ford Maverick Avs bugflector ll installed 1675083826822
bckrupps
Jeremiah
Fort Worth
Damn must be because my warranty replacement lined up perfectly. The original one had similar issues. Maybe realtruck didn't get all the originals removed from stock. I would contact AVS directly like I did. They were quick and sent out a new one. I would think that would eliminate the potential old stock issue. I also had real truck involved and even sent them links to a couple of these threads just to cover myself if a refund was necessary. It was worth the little bit of inconvenience to me as I really wanted one after having one on my Frontier for over 10 years.
OleKennyRoy
Kenny
Maverick Lariat
I dunno, I have three sitting in my garage right now... This one and two replacements. All three have similar fitment issues.
Maybe it's one shift or one work station. I dunno.
@Realtruck
tonyfall1
Tony
2023 XL Hybrid
Bumping this: I ordered this and it arrived without any installation instructions or any sort of install kit. Do I just remove the weather stripping and use the same grommets to install this?
tonyfall1
Tony
2023 XL Hybrid
Thanks,
every install I read seems to indicate I should have received some parts for the install, which I did not receive.
Jah.
Jah.
Jah.
Central Florida
I didn't totally remove the weather strip . just the fasteners needed . should have come with package of plastic grommets .
tonyfall1
Tony
2023 XL Hybrid
thanks.. it looks like i am missing the package of grommets along with the install instructions.
TopCoder
Henry
I been avoiding gettting a bug deflector, because of the tape, when I look at the instructions for for bug deflector II on amazon, it shows it has tape? What am i missing?
