auto stop/start eliminator for 2025 maverick xlt
Maverick72
Al
Dayton, OH
2025 Maverick XLT
mstrbill
Marana,AZ
2024 Lariat FX4, 2017 Beetle Convertible
The picture on Amazon matches your image above. That’s not a plug, that’s the brain of the unit. It’s mentioned in the video that the led flashes when connected.
White Thunder
Donald
Sapulpa, Oklahoma
2022 Maverick XL
Jah.
Jah.
Central Florida
Yea . I have just got in the habit of turning stop/start off each time . 1) back out of garage . 2) close garage door with clicker . 3) buckle seat belts . 4) put on sunglasses . 5 ) start/stop disengage . Started doing this after a couple of months ownership due to battery / sleep warnings . also thought about wear and tear on all the other components that occurred with start/stop . Will leave it up to next owner to delete or use . 3 plus years and just over 10k miles .
Ford Maverick auto stop/start eliminator for 2025 maverick xlt 20221016_085836
EONR24
United States
2024 Ford Maverick XL
Option 1) if you want to permanently disable it, you can disable it via forscan. You can always change the coding back and it will work like it did before.
Option 2) If you want to have it off on start up but have the ability turn it on while driving, go with the auto stop start disabler.
Option 3) The cheapest and easiest way to disable it is to unplug your BMS sensor on your battery but this may cause other warning lights or codes.
All you need for forscan is a windows laptop, an elm327 hs/ms can OBD cable and the software forscan (which you can get a free subscription for)
Maverick72
Al
Dayton, OH
2025 Maverick XLT
OK, I have reviewed the video and now I see it. Thanks.
Merrick
Merrick
Lewes, DE
2025 Maverick Lariat Hybrid AWD
You all know that the system was designed to be most efficient when the start/stp engages. Please understand that you live in 2025 and engines are designed differently than in 1999.
Maverick72
Al
Dayton, OH
2025 Maverick XLT
eyeonmusic
Larry
New York
2025 Ford Maverick XLT
I installed same one two weeks ago. It was worth the money! Works great!
r0tax
CO
2025 Lobo 402A VB
Pretty sure you can do this with Forscan.
For the cost of an OBDII adapter. (Assuming you have a laptop.)
I will be trying it on my 2025 Lobo next time I get my laptop and cable out.
