Auto start/stop activation
N9aVNU
Iowa City, IA
2025 XLT
What causes auto start/stop to activate? Sometimes is comes into use, sometimes not, which confuses me. The symbol is usually greyed out except when it kicks in.
matmondro
Mathieu
Vassar, MI
Depends on a whole host of things. Coolant temp, outside temp, climate control settings/speed, battery voltage, etc. A combination of these needs to fall into an acceptable range for the auto start-stop to activate.
  • Like
Reactions: bgn
d7602002
Joseph
2024 Maverick XLT
If you're curious to know, I believe on your dashboard screen or somewhere you can go under vehicle information and there will be a section that says auto start stop, something similar to that and I believe it actually tells you why it's not shutting off.
The reason I'm not saying it with much confidence and I say I believe, or I think is Ichecked it only once and it said working normally. But I believe I read somewhere on these forums that it tells you more than just that.
Gpp
Gil
Sanford nc
2022 ford maverick
I wish i had this problem but ended up buying a controller to keep it off!
Mox4615
Jeremy
NC
2024 Lariat
Good Rule of thumb is to just turn it off.
Ozarkbeard
Running heat or air may disable A.S.S.
AUTO-START-STOP – FREQUENTLY ASKED QUESTIONS
Why does the engine not always stop when I expect it to?
The system is designed to work in a way that complements other vehicle systems, allowing them to operate at optimum performance.
The system does not stop the engine if:
  • The driver door is open.
  • Your vehicle is at high altitude.
  • The heated windshield is on.
  • The engine is warming up.
  • The outside temperature is too low or too high.
  • The battery charge is low.
  • The battery temperature is outside the optimal operating range.
  • The engine is required to run to maintain interior climate and reduce fogging.
Why does the engine sometimes restart when I do not expect it to?
The system restarts the engine if:
  • You switch the heated windshield on.
  • You switch maximum defrost on.
  • Your vehicle starts to roll downhill in neutral.
  • The engine is required to run to maintain adequate brake system assistance.
Howard
Howard
Indiana
24 Atlas Blue, 2015 Escape
If you turn on the AutoStart/Stop screen on the dash, it will show the reason it is not working. Outside temperature well below freezing, engine temp too cold (first 2 miles), AC working hard can keep it from working, but the main reason I see is vehicle is charging most of the time, even after long drives, etc. I'm going to have it looked at at the next oil change.
